Chromium Kiosk Aspect Ratio issues
  • DietPi version | 9.21.1
  • Distro version | bookworm 0
  • Kernel version | 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
  • Architecture | arm64
  • SBC model | Rpi 3 Model B
  • Power supply used | PC USB port
  • SD card used | Sandisk, I think
  • Software title | Chromium
    Fresh
    Haven’t tried
I have a 7 inch display (vertical) in my computer case. HDMI connected. I’d like the chromium browser in kiosk mode to display a page on the full screen, but atm it’s in a square. I need to know what I should put in the dietpi-config section 1, and in the chromium kiosk settings in dietpi.txt, please.
This is a display very similar, if not identical: Amazon.com
And this is what my screen looks like now: https://ibb.co/hHGqxZb
I don’t have such a screen and my support is limited on your question, but did you already tried to play with resolution settings?
# Chromium
SOFTWARE_CHROMIUM_RES_X=1280
SOFTWARE_CHROMIUM_RES_Y=720
I faced the same problem, the issue was in the “chromium/Default/Preferences” file. See https://unix.stackexchange.com/questions/273989/how-can-i-make-chromium-start-full-screen-under-x
