I am sending this message in a bottle to find out which version of Dietpi to use on my RPi Zero 2W.
I found this blog post The new Raspberry Pi Zero 2 W – Why is DietPi a good match? – DietPi Blog , which recommends using the recommended OS for the RPI 2 v1.1 (the only ARMv7 OS compatible with the RPi), but I’m worried about incompatibility.
Thank you in advance for your help.
Best regards,
Thank you for your reply.
I would like to ask a few questions to better understand, if I may.
Is the blog post that said not to use a 64-bit system too old (or are there two architectures in the image, or is the 64-bit version now much better than the 32-bit version)?
The blog post is 4 years old. Actually we recommend using 64bit If possible
