did you tried to disable IPv6 using dietpi-config as well?
Can you share the error message once IPv6 has been disabled
apt update && apt upgrade
I ran it, but the update still failed. I also ran a custom command recommended by someone (sudo apt update) and it ran, but afterward the same update failed. I am able to reach http://93.93.128.193/ on my wifi, so that is not the problem.
if possible try to avoid doing screen prints. The whole stuff could be copied directly from SSH terminal
how does RPI package source configuration file looks like
cat /etc/apt/sources.list.d/raspi.list
Strange is the apt update works, but the individual package downloads fail.
Please try to do this manually outside of the DietPi update:
apt update
apt upgrade
There is a user in r/dietpi on reddit with exact the same problem (same hardware, exact same error message, maybe even the same user?) and the person on reddit tried apt update (but inside the script with the option to excute an alternative command) but with no success.
(This is a bit offtopic): I checked my config and I was wondering why in my raspi.list it’s archive.raspberrypi.org/debian but in his list it shows raspbian.raspberrypi.org/raspbian
Is this because the first install starts on DietPi 7.9.3 and the mirror in raspi.list is changed during the update or depends it on the hardware / architecture or for some other reason?
nope it depends what your image type is. For RPi we offer 3 different version.
ARMv6 > Raspbian repository 32bit
ARMv7 > Debian repository 32bit
ARMv8 > Debian repository 64bit
raspbian.raspberrypi.org/raspbian/ is indicating the ARMv6 image.
I remember one case where we had a user running some some firewall like a pfsense, who did package inspection and was blocking http traffic to a certain degree.
Okay, I won’t post screen shots ![]()
How do I run code outside of the update? The moment I log in it runs the update automatically. If there was a way just to skip the update, as I don’t think I need it, that would be nice.
That user in Reddit is me; sorry! I was just trying to get as much help as possible. But I will remain here.
I have a Raspberry Pi Zero 2W. Is the ARMv6 image what I need? Or did I get the wrong one?
Theoretically you are fine using the ARMv6 image. And indeed on a first initial setup process, the update is forced automatically. For testing purposes, you could try the other 2 images as well.
Okay. What should I do now? I cannot bypass the update it seems, so I have to try and get through with it. I am attempting to try again on a different wifi router to see if that works
Well you could try the ARMv8 image if you have time and enough spare SD cards ![]()
Let me try it. I’ll get back to you on if it works!
I tried it with ARMv8, but it was the exact same, so I went back to v6.
I think I may have narrowed down the problem. I found this post, and I ran the code on there: https://dietpi.com/forum/t/cant-update-dietpi-failed-to-fetch/5272/1
I’m pretty sure this is a registry problem, as DietPi is trying to download files from port 80 here (http://93.93.128.193/) yet those aren’t there. I ran the code from the other topic, and it seemed to work; it found quite a few of the files that were previously missing, but many it couldn’t fetch.
What did you execute exactly? The link you posted is completely unrelated and it was a complete different topics that has nothing to do with your issue.
Pls could you start up your SBC, cancel the installation once failed. On command line, execute following and post the whole output as text (not as pictures)
Okay. I ran that code in the command line after it failed and was canceled. Here is the text:
[FAILED] DietPi-Update | Unable to continue, DietPi-Update will now terminate.
DietPi v7.9.3 : Update available
- LAN IP : 192.168.197.171 (wlan0)
[ OK ] DietPi-Login | Desired setting in /boot/dietpi.txt was already set: AUTO_SETUP_AUTOMATED=0
root@DietPi:~# apt update && apt upgrade
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 https://archive.raspberrypi.org/debian bullseye InRelease
Reading package lists... Done
55 packages can be upgraded. Run 'apt list --upgradable' to see them.
Calculating upgrade... Done
The following packages will be upgraded:
base-files bsdutils curl dirmngr fdisk firmware-atheros firmware-brcm80211
firmware-iwlwifi firmware-misc-nonfree firmware-realtek gnupg gnupg-l10n
gnupg-utils gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv
libblkid1 libcryptsetup12 libcurl4 libfdisk1 libgmp10 libmount1
libpam-modules libpam-modules-bin libpam-runtime libpam0g libraspberrypi-bin
libraspberrypi0 libsasl2-2 libsasl2-modules-db libseccomp2 libsmartcols1
libssl1.1 libsystemd0 libudev1 libuuid1 mount openssl
raspberrypi-archive-keyring raspberrypi-bootloader raspberrypi-kernel
raspberrypi-sys-mods systemd systemd-sysv systemd-timesyncd sysvinit-utils
tzdata udev util-linux wget zlib1g
55 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 18.6 MB/148 MB of archives.
After this operation, 3437 kB of additional disk space will be used.
Do you want to continue? [Y/n]
I then entered ‘y’, and this is what happened (Sorry for the spam. I can reach http://93.93.128.193/ on my computer using the same wifi, btw):
Do you want to continue? [Y/n] y
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd armhf 247.3-7+rpi1 [4242 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf udev armhf 247.3-7+rpi1 [1430 kB]
Err:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libudev1 armhf 247.3-7+rpi1
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out [IP: 93.93.128.193 80]
Err:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd-sysv armhf 247.3-7+rpi1
Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
Err:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libssl1.1 armhf 1.1.1n-0+deb11u1
Err:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcryptsetup12 armhf 2:2.3.7-1+deb11u1
Err:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libseccomp2 armhf 2.5.1-1+rpi1+deb11u1
Err:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf mount armhf 2.36.1-8+deb11u1
Err:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf zlib1g armhf 1:1.2.11.dfsg-2+deb11u1
Err:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgv armhf 2.2.27-2+deb11u1
Err:11 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsasl2-modules-db armhf 2.1.27+dfsg-2.1+deb11u1
Err:12 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsasl2-2 armhf 2.1.27+dfsg-2.1+deb11u1
Err:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg-utils armhf 2.2.27-2+deb11u1
Err:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgconf armhf 2.2.27-2+deb11u1
Err:15 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-agent armhf 2.2.27-2+deb11u1
Err:16 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg armhf 2.2.27-2+deb11u1
Err:17 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-wks-server armhf 2.2.27-2+deb11u1
Err:18 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf dirmngr armhf 2.2.27-2+deb11u1
Err:19 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-wks-client armhf 2.2.27-2+deb11u1
Err:20 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg-l10n all 2.2.27-2+deb11u1
Err:21 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgsm armhf 2.2.27-2+deb11u1
Err:22 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg all 2.2.27-2+deb11u1
Err:23 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libgmp10 armhf 2:6.2.1+dfsg-1+deb11u1
Err:24 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf tzdata all 2021a-1+deb11u2
Err:25 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf wget armhf 1.21-1+deb11u1
Err:26 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf curl armhf 7.74.0-1.3+deb11u1
Err:27 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl4 armhf 7.74.0-1.3+deb11u1
Err:28 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf openssl armhf 1.1.1n-0+deb11u1
Fetched 5672 kB in 32s (179 kB/s)
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/systemd/libudev1_247.3-7%2brpi1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) Could not connect to raspbian.raspberrypi.org:80 (93.93.128.193), connection timed out [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/s/systemd/systemd-sysv_247.3-7%2brpi1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/o/openssl/libssl1.1_1.1.1n-0%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/cryptsetup/libcryptsetup12_2.3.7-1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/libs/libseccomp/libseccomp2_2.5.1-1%2brpi1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/u/util-linux/mount_2.36.1-8%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/z/zlib/zlib1g_1.2.11.dfsg-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpgv_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/cyrus-sasl2/libsasl2-modules-db_2.1.27%2bdfsg-2.1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/cyrus-sasl2/libsasl2-2_2.1.27%2bdfsg-2.1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gnupg-utils_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpgconf_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpg-agent_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpg_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpg-wks-server_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/dirmngr_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpg-wks-client_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gnupg-l10n_2.2.27-2%2bdeb11u1_all.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gpgsm_2.2.27-2%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gnupg2/gnupg_2.2.27-2%2bdeb11u1_all.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/g/gmp/libgmp10_6.2.1%2bdfsg-1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/t/tzdata/tzdata_2021a-1%2bdeb11u2_all.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/w/wget/wget_1.21-1%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/curl/curl_7.74.0-1.3%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/c/curl/libcurl4_7.74.0-1.3%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Failed to fetch http://raspbian.raspberrypi.org/raspbian/pool/main/o/openssl/openssl_1.1.1n-0%2bdeb11u1_armhf.deb Cannot initiate the connection to raspbian.raspberrypi.org:80 (2a00:1098:0:80:1000:75:0:3). - connect (101: Network is unreachable) [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
What is still strange, it seems your system is trying to contact on IPv6 still. How does it looks like if you try to ping the URL
ping raspbian.raspberrypi.org
root@DietPi:~# ping raspbian.raspberrypi.org
PING mirrordirector.raspbian.org (93.93.128.193) 56(84) bytes of data.
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=1 ttl=50 time=222 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=2 ttl=50 time=202 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=3 ttl=50 time=199 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=4 ttl=50 time=199 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=5 ttl=50 time=197 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=6 ttl=50 time=292 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=7 ttl=50 time=212 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=8 ttl=50 time=204 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=9 ttl=50 time=216 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=10 ttl=50 time=219 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=11 ttl=50 time=278 ms
Ah, I think I forgot to turn off IPv6 this time. Give me a sec; I’ll run it again with it off
Hmm your latency seems to be quite high on the ping. It’s around 200ms. For me it is around 40ms
root@DietPiProd:~# ping -4 raspbian.raspberrypi.org
PING (93.93.128.193) 56(84) bytes of data.
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=1 ttl=49 time=42.9 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=2 ttl=49 time=42.9 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=3 ttl=49 time=43.5 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=4 ttl=49 time=43.4 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=5 ttl=49 time=44.9 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=6 ttl=49 time=42.4 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=7 ttl=49 time=42.6 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=8 ttl=49 time=43.2 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=9 ttl=49 time=42.8 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=10 ttl=49 time=43.1 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=11 ttl=49 time=43.0 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=12 ttl=49 time=43.1 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=13 ttl=49 time=43.5 ms
64 bytes from 93.93.128.193 (93.93.128.193): icmp_seq=14 ttl=49 time=43.8 ms
I tried it yet again, and made sure the IPv6 was off. Something happened this time! I got a green progress bar!
Hit:1 https://archive.raspberrypi.org/debian bullseye InRelease
Hit:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Need to get 12.7 MB/148 MB of archives.
Get:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf systemd-sysv armhf 247.3-7+rpi1 [113 kB]
Get:2 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libssl1.1 armhf 1.1.1n-0+deb11u1 [1279 kB]
Get:3 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcryptsetup12 armhf 2:2.3.7-1+deb11u1 [222 kB]
Get:4 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libseccomp2 armhf 2.5.1-1+rpi1+deb11u1 [47.9 kB]
Get:5 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf mount armhf 2.36.1-8+deb11u1 [177 kB]
Get:6 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf zlib1g armhf 1:1.2.11.dfsg-2+deb11u1 [84.7 kB]
Get:7 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgv armhf 2.2.27-2+deb11u1 [582 kB]
Get:8 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsasl2-modules-db armhf 2.1.27+dfsg-2.1+deb11u1 [67.8 kB]
Get:9 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libsasl2-2 armhf 2.1.27+dfsg-2.1+deb11u1 [98.7 kB]
Get:10 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg-utils armhf 2.2.27-2+deb11u1 [797 kB]
Get:11 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgconf armhf 2.2.27-2+deb11u1 [525 kB]
Get:12 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-agent armhf 2.2.27-2+deb11u1 [616 kB]
Get:13 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg armhf 2.2.27-2+deb11u1 [827 kB]
Get:14 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-wks-server armhf 2.2.27-2+deb11u1 [498 kB]
Get:15 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf dirmngr armhf 2.2.27-2+deb11u1 [704 kB]
Get:16 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpg-wks-client armhf 2.2.27-2+deb11u1 [503 kB]
Get:17 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg-l10n all 2.2.27-2+deb11u1 [1085 kB]
Get:18 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gpgsm armhf 2.2.27-2+deb11u1 [600 kB]
Get:19 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf gnupg all 2.2.27-2+deb11u1 [825 kB]
Get:20 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libgmp10 armhf 2:6.2.1+dfsg-1+deb11u1 [509 kB]
Get:21 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf tzdata all 2021a-1+deb11u2 [284 kB]
Get:22 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf wget armhf 1.21-1+deb11u1 [922 kB]
Get:23 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf curl armhf 7.74.0-1.3+deb11u1 [254 kB]
Get:24 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libcurl4 armhf 7.74.0-1.3+deb11u1 [305 kB]
Get:25 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf openssl armhf 1.1.1n-0+deb11u1 [817 kB]
Fetched 12.7 MB in 44s (287 kB/s)
(Reading database ... 22297 files and directories currently installed.)
Preparing to unpack .../base-files_11.1+rpi1+deb11u3_armhf.deb ...
Unpacking base-files (11.1+rpi1+deb11u3) over (11.1+rpi1+deb11u1) ...
Setting up base-files (11.1+rpi1+deb11u3) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../bsdutils_1%3a2.36.1-8+deb11u1_armhf.deb ...
Unpacking bsdutils (1:2.36.1-8+deb11u1) over (1:2.36.1-8) ...
Setting up bsdutils (1:2.36.1-8+deb11u1) ...
Preparing to unpack .../libblkid1_2.36.1-8+deb11u1_armhf.deb ...
Unpacking libblkid1:armhf (2.36.1-8+deb11u1) over (2.36.1-8) ...
Setting up libblkid1:armhf (2.36.1-8+deb11u1) ...
Preparing to unpack .../libuuid1_2.36.1-8+deb11u1_armhf.deb ...
Unpacking libuuid1:armhf (2.36.1-8+deb11u1) over (2.36.1-8) ...
Setting up libuuid1:armhf (2.36.1-8+deb11u1) ...
Preparing to unpack .../libfdisk1_2.36.1-8+deb11u1_armhf.deb ...
Unpacking libfdisk1:armhf (2.36.1-8+deb11u1) over (2.36.1-8) ...
Preparing to unpack .../libmount1_2.36.1-8+deb11u1_armhf.deb ...
Unpacking libmount1:armhf (2.36.1-8+deb11u1) over (2.36.1-8) ...
Setting up libmount1:armhf (2.36.1-8+deb11u1) ...
Preparing to unpack .../libsmartcols1_2.36.1-8+deb11u1_armhf.deb ...
Unpacking libsmartcols1:armhf (2.36.1-8+deb11u1) over (2.36.1-8) ...
Setting up libsmartcols1:armhf (2.36.1-8+deb11u1) ...
Preparing to unpack .../fdisk_2.36.1-8+deb11u1_armhf.deb ...
Unpacking fdisk (2.36.1-8+deb11u1) over (2.36.1-8) ...
Preparing to unpack .../util-linux_2.36.1-8+deb11u1_armhf.deb ...
Unpacking util-linux (2.36.1-8+deb11u1) over (2.36.1-8) ...
Setting up util-linux (2.36.1-8+deb11u1) ...
fstrim.service is a disabled or a static unit not running, not starting it.
Preparing to unpack .../sysvinit-utils_2.96-7+deb11u1_armhf.deb ...
Unpacking sysvinit-utils (2.96-7+deb11u1) over (2.96-7) ...
Setting up sysvinit-utils (2.96-7+deb11u1) ...
Preparing to unpack .../libpam0g_1.4.0-9+deb11u1+rpt1_armhf.deb ...
Unpacking libpam0g:armhf (1.4.0-9+deb11u1+rpt1) over (1.4.0-9+deb11u1) ...
Setting up libpam0g:armhf (1.4.0-9+deb11u1+rpt1) ...
Preparing to unpack .../libpam-modules-bin_1.4.0-9+deb11u1+rpt1_armhf.deb ...
Unpacking libpam-modules-bin (1.4.0-9+deb11u1+rpt1) over (1.4.0-9+deb11u1) ...
Setting up libpam-modules-bin (1.4.0-9+deb11u1+rpt1) ...
(Cut a little out here so I could post this)
Adding 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Adding 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Adding 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
Adding 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
Adding 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
Adding 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
Adding 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
Adding 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
Adding 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Unpacking raspberrypi-bootloader (1:1.20220331-1) over (1:1.20211118-3) ...
Preparing to unpack .../12-libraspberrypi-bin_1%3a2+git20211125~155417+14b90ff-3_armhf.deb ...
Unpacking libraspberrypi-bin (1:2+git20211125~155417+14b90ff-3) over (1:2+git20211125~155417+14b90ff-2) ...
Preparing to unpack .../13-libraspberrypi0_1%3a2+git20211125~155417+14b90ff-3_armhf.deb ...
Unpacking libraspberrypi0:armhf (1:2+git20211125~155417+14b90ff-3) over (1:2+git20211125~155417+14b90ff-2) ...
Preparing to unpack .../14-openssl_1.1.1n-0+deb11u1_armhf.deb ...
Unpacking openssl (1.1.1n-0+deb11u1) over (1.1.1k-1+deb11u1) ...
Preparing to unpack .../15-raspberrypi-sys-mods_20220224_armhf.deb ...
Unpacking raspberrypi-sys-mods (20220224) over (20211005+bullseye) ...
Setting up systemd-sysv (247.3-7+rpi1) ...
Setting up wget (1.21-1+deb11u1) ...
Setting up firmware-iwlwifi (1:20210315-3+rpt5) ...
Setting up firmware-atheros (1:20210315-3+rpt5) ...
Setting up firmware-misc-nonfree (1:20210315-3+rpt5) ...
Setting up raspberrypi-sys-mods (20220224) ...
Removing vscode repo stubs...
Adding 'flush' option to boot partition...
Failed to try-restart sshswitch.service: Unit sshswitch.service is masked.
Setting up raspberrypi-kernel (1:1.20220331-1) ...
Removing 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Removing 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Removing 'diversion of /boot/kernel7l.img to /usr/share/rpikernelhack/kernel7l.img by rpikernelhack'
Removing 'diversion of /boot/kernel8.img to /usr/share/rpikernelhack/kernel8.img by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b-plus.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-plus.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b-rev1.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b-rev1.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-b.dtb to /usr/share/rpikernelhack/bcm2708-rpi-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-cm.dtb to /usr/share/rpikernelhack/bcm2708-rpi-cm.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-zero-w.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero-w.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2708-rpi-zero.dtb to /usr/share/rpikernelhack/bcm2708-rpi-zero.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2709-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2709-rpi-2-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-2-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-2-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b-plus.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b-plus.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-3-b.dtb to /usr/share/rpikernelhack/bcm2710-rpi-3-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-cm3.dtb to /usr/share/rpikernelhack/bcm2710-rpi-cm3.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-zero-2-w.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2-w.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2710-rpi-zero-2.dtb to /usr/share/rpikernelhack/bcm2710-rpi-zero-2.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-4-b.dtb to /usr/share/rpikernelhack/bcm2711-rpi-4-b.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-400.dtb to /usr/share/rpikernelhack/bcm2711-rpi-400.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-cm4.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4.dtb by rpikernelhack'
Removing 'diversion of /boot/bcm2711-rpi-cm4s.dtb to /usr/share/rpikernelhack/bcm2711-rpi-cm4s.dtb by rpikernelhack'
Removing 'diversion of /boot/COPYING.linux to /usr/share/rpikernelhack/COPYING.linux by rpikernelhack'
Removing 'diversion of /boot/overlays/README to /usr/share/rpikernelhack/overlays/README by rpikernelhack'
Removing 'diversion of /boot/overlays/act-led.dtbo to /usr/share/rpikernelhack/overlays/act-led.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adafruit-st7735r.dtbo to /usr/share/rpikernelhack/overlays/adafruit-st7735r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adafruit18.dtbo to /usr/share/rpikernelhack/overlays/adafruit18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adau1977-adc.dtbo to /usr/share/rpikernelhack/overlays/adau1977-adc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adau7002-simple.dtbo to /usr/share/rpikernelhack/overlays/adau7002-simple.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1015.dtbo to /usr/share/rpikernelhack/overlays/ads1015.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads1115.dtbo to /usr/share/rpikernelhack/overlays/ads1115.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ads7846.dtbo to /usr/share/rpikernelhack/overlays/ads7846.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adv7282m.dtbo to /usr/share/rpikernelhack/overlays/adv7282m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/adv728x-m.dtbo to /usr/share/rpikernelhack/overlays/adv728x-m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/akkordion-iqdacplus.dtbo to /usr/share/rpikernelhack/overlays/akkordion-iqdacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-boss-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-boss2-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-boss2-dac-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-digione.dtbo to /usr/share/rpikernelhack/overlays/allo-digione.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-katana-dac-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-katana-dac-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo to /usr/share/rpikernelhack/overlays/allo-piano-dac-plus-pcm512x-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/anyspi.dtbo to /usr/share/rpikernelhack/overlays/anyspi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/apds9960.dtbo to /usr/share/rpikernelhack/overlays/apds9960.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/applepi-dac.dtbo to /usr/share/rpikernelhack/overlays/applepi-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/at86rf233.dtbo to /usr/share/rpikernelhack/overlays/at86rf233.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-addons.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-addons.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-isolated-soundcard.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-isolated-soundcard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-ultra.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-ultra.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audioinjector-wm8731-audio.dtbo to /usr/share/rpikernelhack/overlays/audioinjector-wm8731-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audiosense-pi.dtbo to /usr/share/rpikernelhack/overlays/audiosense-pi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/audremap.dtbo to /usr/share/rpikernelhack/overlays/audremap.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/balena-fin.dtbo to /usr/share/rpikernelhack/overlays/balena-fin.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cap1106.dtbo to /usr/share/rpikernelhack/overlays/cap1106.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/chipdip-dac.dtbo to /usr/share/rpikernelhack/overlays/chipdip-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cma.dtbo to /usr/share/rpikernelhack/overlays/cma.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/cutiepi-panel.dtbo to /usr/share/rpikernelhack/overlays/cutiepi-panel.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dht11.dtbo to /usr/share/rpikernelhack/overlays/dht11.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco-v2.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dionaudio-loco.dtbo to /usr/share/rpikernelhack/overlays/dionaudio-loco.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/disable-bt.dtbo to /usr/share/rpikernelhack/overlays/disable-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/disable-wifi.dtbo to /usr/share/rpikernelhack/overlays/disable-wifi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi18.dtbo to /usr/share/rpikernelhack/overlays/dpi18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi18cpadhi.dtbo to /usr/share/rpikernelhack/overlays/dpi18cpadhi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dpi24.dtbo to /usr/share/rpikernelhack/overlays/dpi24.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/draws.dtbo to /usr/share/rpikernelhack/overlays/draws.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc-otg.dtbo to /usr/share/rpikernelhack/overlays/dwc-otg.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/dwc2.dtbo to /usr/share/rpikernelhack/overlays/dwc2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/edt-ft5406.dtbo to /usr/share/rpikernelhack/overlays/edt-ft5406.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60-spi2.dtbo to /usr/share/rpikernelhack/overlays/enc28j60-spi2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/enc28j60.dtbo to /usr/share/rpikernelhack/overlays/enc28j60.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/exc3000.dtbo to /usr/share/rpikernelhack/overlays/exc3000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fbtft.dtbo to /usr/share/rpikernelhack/overlays/fbtft.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fe-pi-audio.dtbo to /usr/share/rpikernelhack/overlays/fe-pi-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/fsm-demo.dtbo to /usr/share/rpikernelhack/overlays/fsm-demo.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ghost-amp.dtbo to /usr/share/rpikernelhack/overlays/ghost-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/goodix.dtbo to /usr/share/rpikernelhack/overlays/goodix.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/googlevoicehat-soundcard.dtbo to /usr/share/rpikernelhack/overlays/googlevoicehat-soundcard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-fan.dtbo to /usr/share/rpikernelhack/overlays/gpio-fan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir-tx.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-ir.dtbo to /usr/share/rpikernelhack/overlays/gpio-ir.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-key.dtbo to /usr/share/rpikernelhack/overlays/gpio-key.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-led.dtbo to /usr/share/rpikernelhack/overlays/gpio-led.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-no-bank0-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-bank0-irq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-no-irq.dtbo to /usr/share/rpikernelhack/overlays/gpio-no-irq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-poweroff.dtbo to /usr/share/rpikernelhack/overlays/gpio-poweroff.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/gpio-shutdown.dtbo to /usr/share/rpikernelhack/overlays/gpio-shutdown.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hd44780-lcd.dtbo to /usr/share/rpikernelhack/overlays/hd44780-lcd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hdmi-backlight-hwhack-gpio.dtbo to /usr/share/rpikernelhack/overlays/hdmi-backlight-hwhack-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-amp100.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-amp100.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dac.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplus.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusadc.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusadcpro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusadcpro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplusdsp.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplusdsp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-dacplushd.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-dacplushd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi-pro.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi-pro.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hifiberry-digi.dtbo to /usr/share/rpikernelhack/overlays/hifiberry-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/highperi.dtbo to /usr/share/rpikernelhack/overlays/highperi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28a.dtbo to /usr/share/rpikernelhack/overlays/hy28a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b-2017.dtbo to /usr/share/rpikernelhack/overlays/hy28b-2017.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/hy28b.dtbo to /usr/share/rpikernelhack/overlays/hy28b.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i-sabre-q2m.dtbo to /usr/share/rpikernelhack/overlays/i-sabre-q2m.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-bcm2708.dtbo to /usr/share/rpikernelhack/overlays/i2c-bcm2708.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-mux.dtbo to /usr/share/rpikernelhack/overlays/i2c-mux.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-pwm-pca9685a.dtbo to /usr/share/rpikernelhack/overlays/i2c-pwm-pca9685a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc-gpio.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-rtc.dtbo to /usr/share/rpikernelhack/overlays/i2c-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c-sensor.dtbo to /usr/share/rpikernelhack/overlays/i2c-sensor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c0.dtbo to /usr/share/rpikernelhack/overlays/i2c0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c1.dtbo to /usr/share/rpikernelhack/overlays/i2c1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c3.dtbo to /usr/share/rpikernelhack/overlays/i2c3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c4.dtbo to /usr/share/rpikernelhack/overlays/i2c4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c5.dtbo to /usr/share/rpikernelhack/overlays/i2c5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2c6.dtbo to /usr/share/rpikernelhack/overlays/i2c6.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/i2s-gpio28-31.dtbo to /usr/share/rpikernelhack/overlays/i2s-gpio28-31.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ilitek251x.dtbo to /usr/share/rpikernelhack/overlays/ilitek251x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx219.dtbo to /usr/share/rpikernelhack/overlays/imx219.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx290.dtbo to /usr/share/rpikernelhack/overlays/imx290.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx378.dtbo to /usr/share/rpikernelhack/overlays/imx378.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx477.dtbo to /usr/share/rpikernelhack/overlays/imx477.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/imx519.dtbo to /usr/share/rpikernelhack/overlays/imx519.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-codec.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-codec.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dac.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-dacplus.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-dacplus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqaudio-digi-wm8804-audio.dtbo to /usr/share/rpikernelhack/overlays/iqaudio-digi-wm8804-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/iqs550.dtbo to /usr/share/rpikernelhack/overlays/iqs550.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/irs1125.dtbo to /usr/share/rpikernelhack/overlays/irs1125.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/jedec-spi-nor.dtbo to /usr/share/rpikernelhack/overlays/jedec-spi-nor.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-both.dtbo to /usr/share/rpikernelhack/overlays/justboom-both.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-dac.dtbo to /usr/share/rpikernelhack/overlays/justboom-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/justboom-digi.dtbo to /usr/share/rpikernelhack/overlays/justboom-digi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ltc294x.dtbo to /usr/share/rpikernelhack/overlays/ltc294x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/max98357a.dtbo to /usr/share/rpikernelhack/overlays/max98357a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/maxtherm.dtbo to /usr/share/rpikernelhack/overlays/maxtherm.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mbed-dac.dtbo to /usr/share/rpikernelhack/overlays/mbed-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23017.dtbo to /usr/share/rpikernelhack/overlays/mcp23017.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp23s17.dtbo to /usr/share/rpikernelhack/overlays/mcp23s17.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can0.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515-can1.dtbo to /usr/share/rpikernelhack/overlays/mcp2515-can1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp2515.dtbo to /usr/share/rpikernelhack/overlays/mcp2515.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp251xfd.dtbo to /usr/share/rpikernelhack/overlays/mcp251xfd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp3008.dtbo to /usr/share/rpikernelhack/overlays/mcp3008.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp3202.dtbo to /usr/share/rpikernelhack/overlays/mcp3202.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mcp342x.dtbo to /usr/share/rpikernelhack/overlays/mcp342x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/media-center.dtbo to /usr/share/rpikernelhack/overlays/media-center.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/merus-amp.dtbo to /usr/share/rpikernelhack/overlays/merus-amp.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart0.dtbo to /usr/share/rpikernelhack/overlays/midi-uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart1.dtbo to /usr/share/rpikernelhack/overlays/midi-uart1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart2.dtbo to /usr/share/rpikernelhack/overlays/midi-uart2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart3.dtbo to /usr/share/rpikernelhack/overlays/midi-uart3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart4.dtbo to /usr/share/rpikernelhack/overlays/midi-uart4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/midi-uart5.dtbo to /usr/share/rpikernelhack/overlays/midi-uart5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/minipitft13.dtbo to /usr/share/rpikernelhack/overlays/minipitft13.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/miniuart-bt.dtbo to /usr/share/rpikernelhack/overlays/miniuart-bt.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mipi-dbi-spi.dtbo to /usr/share/rpikernelhack/overlays/mipi-dbi-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mlx90640.dtbo to /usr/share/rpikernelhack/overlays/mlx90640.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mmc.dtbo to /usr/share/rpikernelhack/overlays/mmc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mpu6050.dtbo to /usr/share/rpikernelhack/overlays/mpu6050.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/mz61581.dtbo to /usr/share/rpikernelhack/overlays/mz61581.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov2311.dtbo to /usr/share/rpikernelhack/overlays/ov2311.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov5647.dtbo to /usr/share/rpikernelhack/overlays/ov5647.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov7251.dtbo to /usr/share/rpikernelhack/overlays/ov7251.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ov9281.dtbo to /usr/share/rpikernelhack/overlays/ov9281.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/overlay_map.dtb to /usr/share/rpikernelhack/overlays/overlay_map.dtb by rpikernelhack'
Removing 'diversion of /boot/overlays/papirus.dtbo to /usr/share/rpikernelhack/overlays/papirus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pca953x.dtbo to /usr/share/rpikernelhack/overlays/pca953x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pcie-32bit-dma.dtbo to /usr/share/rpikernelhack/overlays/pcie-32bit-dma.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pibell.dtbo to /usr/share/rpikernelhack/overlays/pibell.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifacedigital.dtbo to /usr/share/rpikernelhack/overlays/pifacedigital.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-40.dtbo to /usr/share/rpikernelhack/overlays/pifi-40.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-dac-hd.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-hd.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-dac-zero.dtbo to /usr/share/rpikernelhack/overlays/pifi-dac-zero.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pifi-mini-210.dtbo to /usr/share/rpikernelhack/overlays/pifi-mini-210.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piglow.dtbo to /usr/share/rpikernelhack/overlays/piglow.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen.dtbo to /usr/share/rpikernelhack/overlays/piscreen.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/piscreen2r.dtbo to /usr/share/rpikernelhack/overlays/piscreen2r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pisound.dtbo to /usr/share/rpikernelhack/overlays/pisound.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft22.dtbo to /usr/share/rpikernelhack/overlays/pitft22.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-capacitive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-capacitive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft28-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft28-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pitft35-resistive.dtbo to /usr/share/rpikernelhack/overlays/pitft35-resistive.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pps-gpio.dtbo to /usr/share/rpikernelhack/overlays/pps-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-2chan.dtbo to /usr/share/rpikernelhack/overlays/pwm-2chan.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm-ir-tx.dtbo to /usr/share/rpikernelhack/overlays/pwm-ir-tx.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/pwm.dtbo to /usr/share/rpikernelhack/overlays/pwm.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000-uart0.dtbo to /usr/share/rpikernelhack/overlays/qca7000-uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/qca7000.dtbo to /usr/share/rpikernelhack/overlays/qca7000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rotary-encoder.dtbo to /usr/share/rpikernelhack/overlays/rotary-encoder.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-backlight.dtbo to /usr/share/rpikernelhack/overlays/rpi-backlight.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-cirrus-wm5102.dtbo to /usr/share/rpikernelhack/overlays/rpi-cirrus-wm5102.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-dac.dtbo to /usr/share/rpikernelhack/overlays/rpi-dac.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-display.dtbo to /usr/share/rpikernelhack/overlays/rpi-display.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-ft5406.dtbo to /usr/share/rpikernelhack/overlays/rpi-ft5406.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-poe-plus.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe-plus.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-poe.dtbo to /usr/share/rpikernelhack/overlays/rpi-poe.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-proto.dtbo to /usr/share/rpikernelhack/overlays/rpi-proto.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-sense.dtbo to /usr/share/rpikernelhack/overlays/rpi-sense.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpi-tv.dtbo to /usr/share/rpikernelhack/overlays/rpi-tv.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rpivid-v4l2.dtbo to /usr/share/rpikernelhack/overlays/rpivid-v4l2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/rra-digidac1-wm8741-audio.dtbo to /usr/share/rpikernelhack/overlays/rra-digidac1-wm8741-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sainsmart18.dtbo to /usr/share/rpikernelhack/overlays/sainsmart18.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is750-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is750-i2c.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-i2c.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-i2c.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-spi0.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sc16is752-spi1.dtbo to /usr/share/rpikernelhack/overlays/sc16is752-spi1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdhost.dtbo to /usr/share/rpikernelhack/overlays/sdhost.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sdio.dtbo to /usr/share/rpikernelhack/overlays/sdio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v1.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/seeed-can-fd-hat-v2.dtbo to /usr/share/rpikernelhack/overlays/seeed-can-fd-hat-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sh1106-spi.dtbo to /usr/share/rpikernelhack/overlays/sh1106-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/si446x-spi0.dtbo to /usr/share/rpikernelhack/overlays/si446x-spi0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-dev.dtbo to /usr/share/rpikernelhack/overlays/smi-dev.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi-nand.dtbo to /usr/share/rpikernelhack/overlays/smi-nand.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/smi.dtbo to /usr/share/rpikernelhack/overlays/smi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-gpio35-39.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio35-39.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-gpio40-45.dtbo to /usr/share/rpikernelhack/overlays/spi-gpio40-45.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi-rtc.dtbo to /usr/share/rpikernelhack/overlays/spi-rtc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-0cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-0cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi0-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi0-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi1-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi1-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi2-3cs.dtbo to /usr/share/rpikernelhack/overlays/spi2-3cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi3-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi3-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi3-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi4-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi4-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi4-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi5-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi5-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi5-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi6-1cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-1cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/spi6-2cs.dtbo to /usr/share/rpikernelhack/overlays/spi6-2cs.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1306-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1306-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1306.dtbo to /usr/share/rpikernelhack/overlays/ssd1306.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1331-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1331-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ssd1351-spi.dtbo to /usr/share/rpikernelhack/overlays/ssd1351-spi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/superaudioboard.dtbo to /usr/share/rpikernelhack/overlays/superaudioboard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/sx150x.dtbo to /usr/share/rpikernelhack/overlays/sx150x.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tc358743-audio.dtbo to /usr/share/rpikernelhack/overlays/tc358743-audio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tc358743.dtbo to /usr/share/rpikernelhack/overlays/tc358743.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tinylcd35.dtbo to /usr/share/rpikernelhack/overlays/tinylcd35.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/tpm-slb9670.dtbo to /usr/share/rpikernelhack/overlays/tpm-slb9670.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart0.dtbo to /usr/share/rpikernelhack/overlays/uart0.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart1.dtbo to /usr/share/rpikernelhack/overlays/uart1.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart2.dtbo to /usr/share/rpikernelhack/overlays/uart2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart3.dtbo to /usr/share/rpikernelhack/overlays/uart3.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart4.dtbo to /usr/share/rpikernelhack/overlays/uart4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/uart5.dtbo to /usr/share/rpikernelhack/overlays/uart5.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/udrc.dtbo to /usr/share/rpikernelhack/overlays/udrc.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/ugreen-dabboard.dtbo to /usr/share/rpikernelhack/overlays/ugreen-dabboard.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/upstream-pi4.dtbo to /usr/share/rpikernelhack/overlays/upstream-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/upstream.dtbo to /usr/share/rpikernelhack/overlays/upstream.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-fkms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-fkms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-fkms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-generic.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-generic.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel2r.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel2r.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-hyperpixel4sq.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dpi-panel.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dpi-panel.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-7inch.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000-v2.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-dsi-lt070me05000.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-dsi-lt070me05000.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-kippah-7inch.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-kippah-7inch.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d-pi4.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d-pi4.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-v3d.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-v3d.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vc4-kms-vga666.dtbo to /usr/share/rpikernelhack/overlays/vc4-kms-vga666.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vga666.dtbo to /usr/share/rpikernelhack/overlays/vga666.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/vl805.dtbo to /usr/share/rpikernelhack/overlays/vl805.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio-pullup.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio-pullup.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w1-gpio.dtbo to /usr/share/rpikernelhack/overlays/w1-gpio.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/w5500.dtbo to /usr/share/rpikernelhack/overlays/w5500.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-a.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-a.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/waveshare-can-fd-hat-mode-b.dtbo to /usr/share/rpikernelhack/overlays/waveshare-can-fd-hat-mode-b.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.32+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/dietpi-USBridgeSig 5.15.32+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.32-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/dietpi-USBridgeSig 5.15.32-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.32-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/dietpi-USBridgeSig 5.15.32-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 5.15.32-v8+ /boot/kernel8.img
run-parts: executing /etc/kernel/postinst.d/dietpi-USBridgeSig 5.15.32-v8+ /boot/kernel8.img
Setting up tzdata (2021a-1+deb11u2) ...
Current default time zone: 'Africa/Kampala'
Local time is now: Sun Apr 17 15:30:27 EAT 2022.
Universal Time is now: Sun Apr 17 12:30:27 UTC 2022.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up firmware-brcm80211 (1:20210315-3+rpt5) ...
Setting up firmware-realtek (1:20210315-3+rpt5) ...
Setting up systemd-timesyncd (247.3-7+rpi1) ...
Setting up udev (247.3-7+rpi1) ...
Setting up raspberrypi-bootloader (1:1.20220331-1) ...
Removing 'diversion of /boot/start.elf to /usr/share/rpikernelhack/start.elf by rpikernelhack'
Removing 'diversion of /boot/start_cd.elf to /usr/share/rpikernelhack/start_cd.elf by rpikernelhack'
Removing 'diversion of /boot/start_db.elf to /usr/share/rpikernelhack/start_db.elf by rpikernelhack'
Removing 'diversion of /boot/start_x.elf to /usr/share/rpikernelhack/start_x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup.dat to /usr/share/rpikernelhack/fixup.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_cd.dat to /usr/share/rpikernelhack/fixup_cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_db.dat to /usr/share/rpikernelhack/fixup_db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup_x.dat to /usr/share/rpikernelhack/fixup_x.dat by rpikernelhack'
Removing 'diversion of /boot/bootcode.bin to /usr/share/rpikernelhack/bootcode.bin by rpikernelhack'
Removing 'diversion of /boot/start4.elf to /usr/share/rpikernelhack/start4.elf by rpikernelhack'
Removing 'diversion of /boot/start4cd.elf to /usr/share/rpikernelhack/start4cd.elf by rpikernelhack'
Removing 'diversion of /boot/start4db.elf to /usr/share/rpikernelhack/start4db.elf by rpikernelhack'
Removing 'diversion of /boot/start4x.elf to /usr/share/rpikernelhack/start4x.elf by rpikernelhack'
Removing 'diversion of /boot/fixup4.dat to /usr/share/rpikernelhack/fixup4.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4cd.dat to /usr/share/rpikernelhack/fixup4cd.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4db.dat to /usr/share/rpikernelhack/fixup4db.dat by rpikernelhack'
Removing 'diversion of /boot/fixup4x.dat to /usr/share/rpikernelhack/fixup4x.dat by rpikernelhack'
Removing 'diversion of /boot/LICENCE.broadcom to /usr/share/rpikernelhack/LICENCE.broadcom by rpikernelhack'
Setting up raspberrypi-archive-keyring (2021.1.1+rpt1) ...
Setting up libfdisk1:armhf (2.36.1-8+deb11u1) ...
Setting up libraspberrypi0:armhf (1:2+git20211125~155417+14b90ff-3) ...
Setting up mount (2.36.1-8+deb11u1) ...
Setting up libcurl4:armhf (7.74.0-1.3+deb11u1) ...
Setting up libcryptsetup12:armhf (2:2.3.7-1+deb11u1) ...
Setting up curl (7.74.0-1.3+deb11u1) ...
Setting up openssl (1.1.1n-0+deb11u1) ...
Setting up fdisk (2.36.1-8+deb11u1) ...
Setting up libraspberrypi-bin (1:2+git20211125~155417+14b90ff-3) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u2) ...
What do I do now?
