I would like to connect m android phone to the dietpi and play audio to the pi. But the dietpi wont connect to the phone. It does pair.
I have searched the existing open and closed issues but not find a solution
DietPi version | 9.1.1
Distro version | Bookworm
Kernel version | Linux DietPi 6.1.21-v8+ #1642
Architecture | arm64
SBC model | RPi 3 Model B+ (aarch64)
SD card used | SanDisk ultra
Software title | Bluetooth
Software title installed freshly
Steps to reproduce.
Bluetooth activated in dietpi-config, using bluetoothctl managed to pair my android phone but not able to connect using command connect . Get the following error message:
Attempting to connect to XX:XX:XX:73:DE:22
Failed to connect: org.bluez.Error.Failed br-connection-profile-unavailable
I also tried to connect my MacBook, running ubuntu and get the same. It initially connects then immediately disconnects and gives the same message
There are several possible solutions that people on the forum report as working.
I’ve tried:
ControllerMode = bredr
in
/etc/bluetooth/main.conf
# Restricts all controllers to the specified transport. Default value
# is "dual", i.e. both BR/EDR and LE enabled (when supported by the >
# Possible values: "dual", "bredr", "le"
restarted services
No change. The Macbook running ubuntu connects and then disconnects
The Android phone pairs, but does not connect
Some on the forum from the link report installing bluetoothpulse, solves the issue - hence my question “Do we use ALSA on dietpi or Pulse to control bluetooth?”
When I run sudo journalctl -u bluetooth I get
Mar 10 13:51:56 DietPi (uetoothd)[581]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 10 13:51:56 DietPi systemd[1]: Starting bluetooth.service - Bluetooth service...
Mar 10 13:51:56 DietPi bluetoothd[581]: Bluetooth daemon 5.66
Mar 10 13:51:56 DietPi systemd[1]: Started bluetooth.service - Bluetooth service.
Mar 10 13:51:56 DietPi bluetoothd[581]: Starting SDP server
Mar 10 13:51:56 DietPi bluetoothd[581]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 10 13:51:56 DietPi bluetoothd[581]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 10 13:51:56 DietPi bluetoothd[581]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 10 13:51:56 DietPi bluetoothd[581]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 10 13:51:56 DietPi bluetoothd[581]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 10 13:51:56 DietPi bluetoothd[581]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 10 13:51:56 DietPi bluetoothd[581]: Bluetooth management interface 1.22 initialized
Mar 10 13:51:57 DietPi bluetoothd[581]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mar 10 13:51:57 DietPi bluetoothd[581]: sap-server: Operation not permitted (1)
Mar 10 13:51:58 DietPi bluetoothd[581]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mar 10 13:51:58 DietPi bluetoothd[581]: sap-server: Operation not permitted (1)
Mar 10 13:51:58 DietPi bluetoothd[581]: Failed to set privacy: Rejected (0x0b)
Mar 10 13:52:01 DietPi bluetoothd[581]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Mar 10 14:14:55 DietPi systemd[1]: Stopping bluetooth.service - Bluetooth service...
Mar 10 14:14:55 DietPi bluetoothd[581]: Terminating
Mar 10 14:14:55 DietPi bluetoothd[581]: Stopping SDP server
Mar 10 14:14:55 DietPi bluetoothd[581]: Exit
Mar 10 14:14:56 DietPi systemd[1]: bluetooth.service: Deactivated successfully.
Mar 10 14:14:56 DietPi systemd[1]: Stopped bluetooth.service - Bluetooth service.
Mar 10 14:15:06 DietPi systemd[1]: Starting bluetooth.service - Bluetooth service...
Mar 10 14:15:06 DietPi (uetoothd)[2780]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 10 14:15:06 DietPi bluetoothd[2780]: Bluetooth daemon 5.66
Mar 10 14:15:06 DietPi systemd[1]: Started bluetooth.service - Bluetooth service.
Mar 10 14:15:06 DietPi bluetoothd[2780]: Starting SDP server
Mar 10 14:15:06 DietPi bluetoothd[2780]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 10 14:15:06 DietPi bluetoothd[2780]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 10 14:15:06 DietPi bluetoothd[2780]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 10 14:15:06 DietPi bluetoothd[2780]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 10 14:15:06 DietPi bluetoothd[2780]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 10 14:15:06 DietPi bluetoothd[2780]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 10 14:15:06 DietPi bluetoothd[2780]: Bluetooth management interface 1.22 initialized
Mar 10 14:15:06 DietPi bluetoothd[2780]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mar 10 14:15:06 DietPi bluetoothd[2780]: sap-server: Operation not permitted (1)
Mar 10 14:21:22 DietPi bluetoothd[2780]: Terminating
Mar 10 14:21:22 DietPi systemd[1]: Stopping bluetooth.service - Bluetooth service...
Mar 10 14:21:22 DietPi bluetoothd[2780]: Stopping SDP server
Mar 10 14:21:22 DietPi systemd[1]: bluetooth.service: Deactivated successfully.
Mar 10 14:21:22 DietPi bluetoothd[2780]: Exit
Mar 10 14:21:22 DietPi systemd[1]: Stopped bluetooth.service - Bluetooth service.
Mar 10 14:21:22 DietPi systemd[1]: Starting bluetooth.service - Bluetooth service...
Mar 10 14:21:22 DietPi (uetoothd)[3165]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mar 10 14:21:22 DietPi bluetoothd[3165]: Bluetooth daemon 5.66
Mar 10 14:21:22 DietPi systemd[1]: Started bluetooth.service - Bluetooth service.
Mar 10 14:21:22 DietPi bluetoothd[3165]: Starting SDP server
Mar 10 14:21:22 DietPi bluetoothd[3165]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Mar 10 14:21:22 DietPi bluetoothd[3165]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 10 14:21:22 DietPi bluetoothd[3165]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 10 14:21:22 DietPi bluetoothd[3165]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 10 14:21:22 DietPi bluetoothd[3165]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 10 14:21:22 DietPi bluetoothd[3165]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 10 14:21:22 DietPi bluetoothd[3165]: Bluetooth management interface 1.22 initialized
Mar 10 14:21:22 DietPi bluetoothd[3165]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mar 10 14:21:22 DietPi bluetoothd[3165]: sap-server: Operation not permitted (1)
Mar 10 14:25:23 DietPi bluetoothd[3165]: src/service.c:btd_service_connect() a2dp-source profile connect failed for 30:09:C0:73:DE:22: Protocol not available
Device 30:09:C0:73:DE:22 Paired: yes
Pairing successful
[CHG] Device 30:09:C0:73:DE:22 ServicesResolved: no
[CHG] Device 30:09:C0:73:DE:22 Connected: no
systemctl status bluetooth.service
returns
root@DietPi:~# systemctl status bluetooth.service
● bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; preset: enabled)
Drop-In: /etc/systemd/system/bluetooth.service.d
└─dietpi-process_tool.conf, dietpi-services_edit.conf
Active: active (running) since Mon 2024-03-11 07:40:29 GMT; 12min ago
Docs: man:bluetoothd(8)
Main PID: 472 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 779)
CPU: 392ms
CGroup: /system.slice/bluetooth.service
└─472 /usr/libexec/bluetooth/bluetoothd
Mar 11 07:40:29 DietPi bluetoothd[472]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Mar 11 07:40:29 DietPi bluetoothd[472]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 11 07:40:29 DietPi bluetoothd[472]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Mar 11 07:40:29 DietPi bluetoothd[472]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 11 07:40:29 DietPi bluetoothd[472]: Bluetooth management interface 1.22 initialized
Mar 11 07:40:29 DietPi bluetoothd[472]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mar 11 07:40:29 DietPi bluetoothd[472]: sap-server: Operation not permitted (1)
Mar 11 07:40:29 DietPi bluetoothd[472]: Failed to set privacy: Rejected (0x0b)
Mar 11 07:41:42 DietPi bluetoothd[472]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Mar 11 07:48:03 DietPi bluetoothd[472]: src/service.c:btd_service_connect() a2dp-source profile connect failed for 30:09:C0:73:DE:22: Protocol not available
I managed to connect and old iPad ! but not my phone… very odd
Hm it’s already paired, did you try also trust and connect?
I also think, when it’s working with another device there is maybe a incompatibility with the motorola phone.
