Bazarr is not reachable on Dietpi anymore (does not start?)
  • DietPi version 9.0.2 - Native PC
  • Software title | Bazarr
  • Software was installed and it worked. now after powering up my server again, everything works except Bazarr. its not reachable under :6767
  • i swapt my media HDD, and pointed within sonarr/radarr to my my media HDD. could reach these *arrs without an issue
root@DietPi:~# dietpi-software install 180
[  OK  ] DietPi-Software | Initialised database
[  OK  ] DietPi-Software | Reading database
 DietPi-Software
 Mode: Automated install
[ INFO ] DietPi-Software | 180: Bazarr is already installed
[ INFO ] DietPi-Software | Use "dietpi-software reinstall 180" to force rerun of installation and configuration steps for Bazarr.
[  OK  ] DietPi-Software | No changes applied for: Bazarr
and
root@DietPi:~# systemctl restart bazarr
service seems to run and all looks good.
my question is to how do I β€œre-install” it without loosing my Bazarr configuration.
can you check following
ss -tulpn | grep LISTEN
journalctl -u bazarr.service
systemctl status bazarr.service
It’s even in the output of the failed install attempt:
for the first comment, the output is to long for here. so I pasted it here:
https://pastecode.io/s/yxk8fqwk
it seems that’s an issue with the media HDD which I swapped.
therefore de-installed bazarr via dietpi-launcher, and installed it fresh again. then rebooted my server.
gonna start fresh
I guess you are using different mount point for the new HDD leading to the issue. But you would need to use old mount point to fix this.
Can you share
i have already deleted Bazarr and re-installed it. so now I can configure it again with the correct media HDD. thanks though for your help.
