How to do this?
I need to refresh my tab every 15 seconds. I tried some examples online for xdotool but nothing is working.
Thank you
How to do this?
Thank you
many thanks for your question. Is this an own web site or some external one? If it’s an own one, you could try to add a refresh into the site.
Sadly I kust do it from the SBC
I gave installed a software which updates web page at mane locations.
And I need to install more SBC at those locations
So must use xdotool
ok looks like I was not clear enough. Let’s rephrase the question. Are you the owner of that web site? Are you able to add some html code on it?
yes I can add code
you could try adding a meta tag to refresh side automatically into your header https://www.w3schools.com/tags/att_meta_http_equiv.asp
