I’ve got fan running on my Pi, but it’s on all the time.
I’ve seen some solutions to have the come on automatically when the Pi’s temperature rises above a pre-determined level. However, executing the various shells and scripts etc is way beyond my current capabilities.
Is there a simple/easy way to install this functionality, ie is there an ‘app’ or a cut and paste of some code that I can utilise?
I know I was very impressed with the speed of delivery.
Although I’ve adjusted the value in the command down to 60000 the Pi is still getting to over 60 degrees. And the Pi tells me it’s hot, but not unsafe. Should I bring the value down?
Are you able to point me in the direction of a stress test?
