Audiio issues on PC installation
I am not sure if this is bug or hardware issue on PCs. I installed diepi (Native PC x86-64) on two similar PCs. I like the features and slim size of dietpi OS, compared to other linux OSes. The installation is fine and I am using the lxde graphical desktop. However there is no sound.
I followed all the help available on web to set dietpi-config → audio options /boombox settings. But it doesn’t work. If I removed all audio features, and use the automatic detection and installation of drivers, the sound works on vlc player. The sound on vlc however either worked or not worked on different days, not sure what is causing it to work or not work. But I never got sound from any video/audio playing on browser. There are no error messages, but sound is simply not there.
I tried to follow some online help, by using commands like “aplay -l”, reinstalling alsa-utils, but unable to get sound.
I appreciate any help to troubleshoot and get sound.
Maybe something @MichaIng is able to assist with
What does lsusb -v and/or lspci -v have for your audio adapter.
Thank you for reply. I see audio in the lspci output. I attached both outputs.
lsusb.log (23.4 KB)
lsusb.log
Negotiated speed: High Speed (480Mbps)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceSubClass         0 [unknown]
  bDeviceProtocol         0 Full speed (or root) hub
  bMaxPacketSize0        64
  idVendor           0x1d6b Linux Foundation
  idProduct          0x0002 2.0 root hub
  bcdDevice            6.12
  iManufacturer           3 Linux 6.12.48+deb13-amd64 ehci_hcd
  iProduct                2 EHCI Host Controller
  iSerial                 1 0000:00:1d.0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         9 Hub
      bInterfaceSubClass      0 [unknown]
      bInterfaceProtocol      0 Full speed (or root) hub
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0004  1x 4 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
  wHubCharacteristic 0x000a
    No power switching (usb 1.0)
    Per-port overcurrent protection
  bPwrOn2PwrGood       10 * 2 milli seconds
  bHubContrCurrent      0 milli Ampere
  DeviceRemovable    0x02
  PortPwrCtrlMask    0xff
 Hub Port Status:
   Port 1: 0000.0503 highspeed power enable connect
   Port 2: 0000.0100 power
Device Status:     0x0001
  Self Powered
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bDeviceProtocol         1 Single TT
  bMaxPacketSize0        64
  idVendor           0x8087 Intel Corp.
  idProduct          0x0024 Integrated Rate Matching Hub
  bcdDevice            0.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0002  1x 2 bytes
        bInterval              12
Hub Descriptor:
  bLength              11
  bDescriptorType      41
  nNbrPorts             8
  wHubCharacteristic 0x0009
    Per-port power switching
    TT think time 8 FS bits
  bPwrOn2PwrGood       50 * 2 milli seconds
  DeviceRemovable    0x00 0x00
  PortPwrCtrlMask    0xff 0xff
 Hub Port Status:
   Port 1: 0000.0100 power
   Port 3: 0000.0100 power
   Port 4: 0000.0100 power
   Port 5: 0000.0503 highspeed power enable connect
   Port 6: 0000.0100 power
   Port 7: 0000.0100 power
   Port 8: 0000.0507 highspeed power suspend enable connect
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 004: ID 0424:2412 Microchip Technology, Inc. (formerly SMSC) Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  idVendor           0x0424 Microchip Technology, Inc. (formerly SMSC)
  idProduct          0x2412 Hub
  bcdDevice            b.b2
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                2mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0001  1x 1 bytes
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
  bHubContrCurrent      1 milli Ampere
 Hub Port Status:
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 001 Device 005: ID 0bc2:50a5 Seagate RSS LLC FreeAgent GoFlex Desk USB 3.0
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.10
  bDeviceClass            0 [unknown]
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x0bc2 Seagate RSS LLC
  idProduct          0x50a5 FreeAgent GoFlex Desk USB 3.0
  bcdDevice            1.00
  iManufacturer           2 Seagate
  iProduct                3 GoFlex Desk
  iSerial                 1 NA0MHE8Y
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0020
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xc0
      Self Powered
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         8 Mass Storage
      bInterfaceSubClass      6 SCSI
      bInterfaceProtocol     80 Bulk-Only
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Binary Object Store Descriptor:
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x0016
  bNumDeviceCaps          2
  USB 2.0 Extension Device Capability:
    bLength                 7
    bDescriptorType        16
    bDevCapabilityType      2
    bmAttributes   0x00000000
      (Missing must-be-set LPM bit!)
  SuperSpeed USB Device Capability:
    bLength                10
    bDescriptorType        16
    bDevCapabilityType      3
    bmAttributes         0x00
    wSpeedsSupported   0x000e
      Device can operate at Full Speed (12Mbps)
      Device can operate at High Speed (480Mbps)
      Device can operate at SuperSpeed (5Gbps)
    bFunctionalitySupport   1
      Lowest fully-functional device speed is Full Speed (12Mbps)
    bU1DevExitLat          10 micro seconds
    bU2DevExitLat        2047 micro seconds
  Self Powered
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.12
  iSerial                 1 0000:00:1a.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
 Hub Port Status:
  Self Powered
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            0.00
  iManufacturer           0
  iProduct                0
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             6
 Hub Port Status:
   Port 4: 0000.0303 lowspeed power enable connect
   Port 5: 0000.0100 power
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  Self Powered
Bus 002 Device 004: ID 0461:4d81 Primax Electronics, Ltd Dell N889 Optical Mouse
Negotiated speed: Low Speed (1Mbps)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0461 Primax Electronics, Ltd
  idProduct          0x4d81 Dell N889 Optical Mouse
  bcdDevice            2.00
  iManufacturer           0
  iProduct                2 USB Optical Mouse
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               98mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      1 Boot Interface Subclass
      bInterfaceProtocol      2 Mouse
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 (null)
          wDescriptorLength      71
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0006  1x 6 bytes
        bInterval              10
Device Status:     0x0000
  (Bus Powered)
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            9 Hub
  bMaxPacketSize0        64
  bcdDevice            6.12
  iManufacturer           3 Linux 6.12.48+deb13-amd64 xhci-hcd
  iProduct                2 xHCI Host Controller
  iSerial                 1 0000:08:00.0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0019
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
Hub Descriptor:
  bLength               9
  bDescriptorType      41
  nNbrPorts             2
 Hub Port Status:
   Port 1: 0000.0303 lowspeed power enable connect
  Self Powered
Bus 003 Device 002: ID 413c:2107 Dell Computer Corp. KB212-B Quiet Key Keyboard
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               1.10
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x413c Dell Computer Corp.
  idProduct          0x2107 KB212-B Quiet Key Keyboard
  bcdDevice            1.78
  iManufacturer           1 DELL
  iProduct                2 Dell USB Entry Keyboard
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0022
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower              100mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceProtocol      1 Keyboard
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength      65
          Report Descriptors:
            ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0008  1x 8 bytes
        bInterval              10
  (Bus Powered)
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Negotiated speed: SuperSpeed (5Gbps)
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               3.00
  bDeviceClass            9 Hub
  bDeviceProtocol         3
  bMaxPacketSize0         9
  idProduct          0x0003 3.0 root hub
  bcdDevice            6.12
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x001f
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0xe0
      Self Powered
      Remote Wakeup
    MaxPower                0mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              12
        bMaxBurst               0
  bLength                 5
  bDescriptorType        15
  wTotalLength       0x000f
  bNumDeviceCaps          1
    bLength                10
    bDescriptorType        16
    bmAttributes         0x02
      Latency Tolerance Messages (LTM) Supported
    wSpeedsSupported   0x0008
    bU1DevExitLat           0 micro seconds
    bU2DevExitLat           0 micro seconds
Hub Descriptor:
  bLength              12
  bDescriptorType      42
  nNbrPorts             2
  bHubDecLat          0.0 micro seconds
  wHubDelay             0 nano seconds
 Hub Port Status:
   Port 1: 0000.02a0 5Gbps power Rx.Detect
   Port 2: 0000.02a0 5Gbps power Rx.Detect
  Self Powered
lspci.log (1.9 KB)
lspci.log
00:1b.0 Audio device: Intel Corporation C600/X79 series chipset High Definition Audio Controller (rev 05)
	DeviceName:  Onboard Audio
	Subsystem: Dell Device 0497
	Flags: bus master, fast devsel, latency 0, IRQ 45
	Memory at fbf20000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [50] Power Management version 2
	Capabilities: [60] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Root Complex Integrated Endpoint, IntMsgNum 0
	Capabilities: [100] Virtual Channel
	Capabilities: [130] Root Complex Link
	Kernel driver in use: snd_hda_intel
	Kernel modules: snd_hda_intel
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
	Subsystem: Dell Device aab0
	Flags: bus master, fast devsel, latency 0, IRQ 46
	Memory at fbe60000 (64-bit, non-prefetchable) [size=16K]
	Capabilities: [48] Vendor Specific Information: Len=08 <?>
	Capabilities: [50] Power Management version 3
	Capabilities: [58] Express Legacy Endpoint, IntMsgNum 0
	Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
	Capabilities: [150] Advanced Error Reporting
06:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series]
	Flags: bus master, fast devsel, latency 0, IRQ 47
	Memory at fbd60000 (64-bit, non-prefetchable) [size=16K]
The lsusb command looks like I would expect.
Did you remove parts of the lspci output? If not, it doesn’t look like it should. If you did, it is probably ok.
Your computer has four audio ‘adapters’, that can/will cause you headaches, the system could use the wrong one which may not have speakers connected.
Did you install it as a VM? I know you said native but there is QEMU hardware present.
When you are trying to play something in VLC and it is silent (this is from memory) open the Audio menu and then Devices, see what is in the list and try the other options.
Yes I removed the other parts in lspci ouput. I can send the whole file if needed.
This is not a VM installation. I have virtualbox installed but it doesn’t have anything in it yet. Probably that is the reason for QEMU ?
vlc now shows the following: I tried other audio devices, but it is giving Device or resource busy.
Try launching VLC as root.
Otherwise, do you have the history saved of everything you’ve done to try and fix it?
vlc is not running as root.
Regarding history, do you mean dmesg or syslog ? I haven’t kept other records of history.
I just ran dietpi-config again. I disabled and reinstalled audio. I attached log.
dietpi-config.log (7.4 KB)
I ran vlc (normal user) from command line. Got the following messages. It is not working when I change audio devices.
vlc.log (1.5 KB)
The commands you used and settings you changed. :wink:
Other overview of detected sound cards:
aplay -l
Indeed 3 pop up in lsusb/lspci (I do not see a 4th?): The AMD ones will be for HDMI audio, and the Intel one for 3.5mm jack. They should also show up in dietpi-config audio options. The one selected there will be set as default audio device, used by most software by default. But good players allow to select other audio devices explicitly, like you tried in VLC.
Indeed permissions might be needed for that. Try to add your user to the audio group:
sudo usermod -aG audio "$USER"
In other cases, if software uses the “default” ALSA device: There is an auto-conversion option in dietpi-config for ALSA to automatically convert audio streams (channels, sampling rate etc) to the closest one supported by the output device.
The particular error in VLC however indicates that something else is using the audio device already. ALSA device usage is blocking by default. Try to use only one player at a time. But there is also an ALSA plugin “dmix” to allow concurrent usage/mix streams. To test:
cat << '_EOF_' | sudo tee /etc/asound.conf
pcm.!default "dmix:0,0"
ctl.!default {
	type hw
	card 0
_EOF_
This is for card 0 device 0. Adjust depending on which actual audio device you are using. Or combined with the “plug” plugin (auto-conversion):
pcm.!default {
	type plug
	slave.pcm "dmix:0,0"
ctl.!default {
	type hw
	card 0
_EOF_
Just not sure whether the “plug” PCM blocks multi-usage in this case?
I am sorry for late reply, as I couldn’t get to work on this earlier.
I tried the two suggestions above, of changing the /etc/asound.conf. It did not work. I tried changing volumes in alsamixer, but it did not work. I left it there, as I wanted to work on the settings a bit more when I get time. I had to restart the system once. I had the first mentioned configuration of /etc/asound.conf then.
pcm.!default “dmix:0,0”
ctl.!default {
type hw
card 0
Suddently when I played a video the sound was working!
So the above configuration (1st one) is actually the solution. I used the same configuration on the other PC. After a restart the sound is working!
Thanks for the solution. If you could briefly explain why it did not work, and why it works now, with the above configuration, it will be of great help to understand some basics.
Thank you.
I have a question regarding dietpc-drivemanager. Should I create a new thread for it, or can I ask it here?
Pls a new topic in this case
Okay, great that it helped.
Might be still interesting to find out what else is accessing the audio device. Obviously this other player/process is not actually sending a (sufficiently loud) audio stream, but keeping the device locked (unless dmix plugin used). Some jukebox/remote control player might do this even if no client/remote is actually connected, but some also have a feature to free the audio device after no stream has been received for X seconds, or similar. Or it is just the desktop environment for playing some GUI sounds. This should be able to fine out:
fuser -v /dev/snd/*
