As for the Roon Web Controller plug-in, I successfully installed it, but it would fail after restarting the system. I also followed the operations in the tutorial, but it still failed. The problem now is that every time the system is restarted, The Roon Web Controller plug-in can be identified only after the extension of Roon is performed in this step. The steps are 1.cd roon-web-controller, 2.npm install, 3.node app.js. Research for a long time still can not solve, please help
I is according to the site provided by
Installing Roon extension on DietPi tutorial
PLS DON’T DO SCREEN PRINTS. It should be possible to copy directly from SSH terminal aka Putty.
Are you sure you use correct location of app.js
? It doesn’t seems to be located at /root/app.js
? I see following in the guide you linked. /usr/bin/node /root/roon-web-controller/app.js
Anyway, it might be good to contact owner/creator of this guide. He might now what is missing. I’m not sure who we could help on this.
thanks
