DietPi version |
cat /boot/dietpi/.version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=21
G_DIETPI_VERSION_RC=1
G_GITOWNER=‘MichaIng’ -
Distro version |
bullseye bullseye 1 -
Kernel version |
uname -a
Linux DietPi 6.1.21+ #1642 Mon Apr 3 17:19:14 BST 2023 armv6l GNU/Linux -
Architecture |
dpkg --print-architecture
dpkg: error: unknown option --print-architecturedpkg
Type dpkg --help for help about installing and deinstalling packages [*];
Use ‘apt’ or ‘aptitude’ for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through ‘less’ or ‘more’ !
- SBC model |
RPi Zero (armv6l)
5V 1A -
SanDisk Ultra
Base
Was the software title installed freshly or updated/migrated?
Brand new install -
Can this issue be replicated on a fresh installation of DietPi?
Yes
- Bug report ID |
echo $G_HW_UUID
37fa8c75-dd63-4f85-a63a-969315101f67
Freshly created with etcher and started it up , could not even finish the first steps
apt upgrade to work
What happens is this error below :
root@DietPi:/tmp/DietPi-Software# apt upgrade --fix-missing
Reading package lists... Done
Calculating upgrade... Done
The following packages will be upgraded:
libjson-c5
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 38.8 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] Y
Err:1 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf libjson-c5 armhf 0.15-2+deb11u1
400 Bad Request [IP: 45.126.189.130 80]
E: Failed to fetch http://raspbian.mirror.net.in/raspbian/raspbian/pool/main/j/json-c/libjson-c5_0.15-2+deb11u1_armhf.deb 400 Bad Request [IP: 45.126.189.130 80]
None
