Amiberry is set to launch at startup, it does and it works but then quickly closes and then I’m presented with the pi login prompt.
After logging in and trying to launch with systemctl status amiberry – it just hangs.
DietPi version
G_DIETPI_VERSION_CORE=8
G_DIETPI_VERSION_SUB=16
G_DIETPI_VERSION_RC=2
G_LIVE_PATCH_STATUS[0]=‘not applicable’ -
Distro version | buster 1
Kernel version | Linux pimiga 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
Architecture | armhf
SBC model | RPi 400 (armv7l)
Power supply used | 20W 5V/3A
SD card used | SanDisk 64GB ultra
- Software title | Amiberry
Updated. Was working previously.
- Can this issue be replicated on a fresh installation of DietPi? Unknown
- Bug report ID | 79e60f02-e0b2-4322-938c-08a461971d89
- Power on device.
- Amiberry loads and works.
- Amiberry is set to launch at startup, it does and it works but then quickly closes and then I’m presented with the pi login prompt.
journalctl -u amiberry
-- Logs begin at Tue 2023-04-18 16:04:03 AEST, end at Tue 2023-04-18 16:23:03 AEST. --
Apr 18 16:04:05 pimiga systemd[1]: Starting Amiberry Amiga Emulator (DietPi)...
Apr 18 16:04:05 pimiga systemd[1]: Started Amiberry Amiga Emulator (DietPi).
Apr 18 16:04:24 pimiga systemd[1]: amiberry.service: Main process exited, code=killed, status=1/HUP
Apr 18 16:05:55 pimiga systemd[1]: amiberry.service: State 'stop-post' timed out. Terminating.
Apr 18 16:05:55 pimiga systemd[1]: amiberry.service: Control process exited, code=killed, status=15/TERM
Apr 18 16:05:55 pimiga systemd[1]: amiberry.service: Failed with result 'timeout'.
Apr 18 16:05:55 pimiga systemd[1]: Stopped Amiberry Amiga Emulator (DietPi).
Apr 18 16:05:55 pimiga systemd[1]: Starting Amiberry Amiga Emulator (DietPi)...
Apr 18 16:07:25 pimiga systemd[1]: amiberry.service: Start-pre operation timed out. Terminating.
Apr 18 16:07:25 pimiga systemd[1]: amiberry.service: Control process exited, code=killed, status=15/TERM
Apr 18 16:08:55 pimiga systemd[1]: amiberry.service: State 'stop-post' timed out. Terminating.
Apr 18 16:08:55 pimiga systemd[1]: amiberry.service: Control process exited, code=killed, status=15/TERM
Apr 18 16:08:55 pimiga systemd[1]: amiberry.service: Failed with result 'timeout'.
Apr 18 16:08:55 pimiga systemd[1]: Failed to start Amiberry Amiga Emulator (DietPi).
