I am currently running AdGuard Home and Unbound on a Raspberry Pi 5 (192.168.50.3) as well as using a ASUS BE88U router which is on merlin firmware, was wondering what settings should i set on the router as well as the DNS settings within the AdGuard Home web GUI.
I cannot seem to get the hostname of all the devices. My main network IP is 192.168.50.x, while the IP of my guest network which is on another vlan is 192.168.52.x. I used DNS director for guest network to point to the IP of my raspberry pi.
Can anyone advise on the optimal settings for both router as well as in adguard home so that all hostname of devices can properly show up on the client list in adguard home?
Are only hostnames of the guest network devices missing, or from the 192.168.50.0/24 subnet, too?
Do you see the actual 192.168.52.0/24 IP addresses in the AdGuard Home client list, or rather the router’s IP?
Are hostnames for these (either) networks managed in the router or in AdGuard Home?
What I can think of is that the router acts as NAT for (DNS) requests from the guest network, so that AdGuard Home just sees the router doing these, not the actual peers from the guest network. I’d also question the purpose of a guest network, if it can just access a peer in the main LAN directly. So that NAT behavior is certainly exactly what you want.
For hostnames managed by the router, indeed AdGuard Home would need to send PTR (reverse DNS) queries for 192.168.50.0/24/192.168.52.0/24 IPs to the router, instead of to the upstream provider, i.e. conditional forwarding what Jappe mentioned. Not sure whether AdGuard Home supports this, as it is not as configurable as Pi-hole.
adguard home does support that bit. settings, dns settings, add your router as a private reverse dns server and tick use private reverse dns resolver, then the local hostnames show up.
