Activate wake on lan on DietPi
Hi all, I´m pretty new in the Linux/Raspi/DietPi world, so forgive me if I say something wrong.
I basically want to activate the WOL on DietPi in order to turn it on with my Windows laptop. So, I connected it with a LAN cable (eth0) gave it a static ip address and run this command to check sudo ethtool eth0 | grep Wake.
The result shows the following: Supports Wake-on: gs Wake-on: d.
From what I´ve read here https://wiki.archlinux.org/index.php/Wake-on-LAN it means that the WOL it is supported but it has to be activated (because of the “d” after Wake-on, while it should be a “g” in order to be active).
After I ran this command sudo ethtool -s eth0 wol g I get the following result: Cannot set new wake-on-lan settings: Unknown error 524, not setting wol
Does anyone know a solution ? I already googled the error but was unable to find an answer.
Thanks
This depends on whether or not the device supports WoL - the response to the query you give is not always correct in my expereince. I have WoL working on some QNAP devices, an Intel NUC Chinese clone and Intel/AMD desktops but I haven’t got it to work on Odroid SBCs.
What’s the device?
Argh…sorry…it should have been the first thing to write, is a Raspberry Pi 4.
Check and see if this device supports WoL, I’d be surprised if it does. A lot of ARM SBC devices are either power on or off, no intermediate low power state that WoL needs.
Just read Pi4 does not support WoL.
:frowning:
Shame, do you have any link ? I didn´t found any info about it.
https://www.raspberrypi.org/blog/raspberry-pi-4-on-sale-now-from-35/#comment-1510076
Thanks.
It is not related to this issue but just if someone else finds this when searching for wakeonlan package to wake other devices from DietPi: It requires the netbase package but does not pull it automatically as dependency, hence:
apt install wakeonlan netbase
is required to use it. etherwake is an alternative that does not require this.
@Michalng
I did find this: and do need that info, thanks!
I was able to find the MAC via
ip neigh
that shows the ARP table, I think? My recent PING to the server at 192.168.11.53 was in there.
source here
To send that packet: If your MAC address were xx:yy:zz:11:22:33, you would type:
$ wakeonlan xx:yy:zz:11:22:33
https://www.cyberciti.biz/tips/linux-send-wake-on-lan-wol-magic-packets.html
in my dietpi nuc WOL is working based on this thread. & it is working fine
