Service doesn’t start correctly. I’m using SofaPlay on my Mac as a client for streamming. It shows DietPi but when I press play … nothing happens.
Had tested before with RoonBridge and it worked like a charme with output thru SPDIF DigiOne.
here is the results :::
root@DietPi:~# systemctl status gmrender -l
● gmrender.service - GMediaRender (DietPi)
Loaded: loaded (/etc/systemd/system/gmrender.service; disabled; vendor preset: enabled)
Active: active (running) since Thu 2019-12-12 17:07:35 -03; 26min ago
Process: 644 ExecStartPre=/usr/bin/touch /var/log/gmrender.log (code=exited, status=0/SUCCESS)
Process: 645 ExecStartPre=/bin/chown gmrender:dietpi /var/log/gmrender.log (code=exited, status=0/SUCCESS)
Main PID: 646 (dash)
Tasks: 21 (limit: 4915)
Memory: 156.1M
CGroup: /system.slice/gmrender.service
├─646 /bin/dash -c gmediarender -u “20fc1862-ecff-4773-b5a6-033ef6ab6f8c” -f “DietPi” --gstout-audiodevice=sysdefault --gstout-initial-volume-db=-1 --logfile=/var/log/gmrender.log -I
“$(sed -n 4p /DietPi/dietpi/.network)”
└─649 gmediarender -u 20fc1862-ecff-4773-b5a6-033ef6ab6f8c -f DietPi --gstout-audiodevice=sysdefault --gstout-initial-volume-db=-1 --logfile=/var/log/gmrender.log -I 192.168.1.109
Dec 12 17:07:48 DietPi gmediarender[649]: gst_bin_add: assertion ‘GST_IS_ELEMENT (element)’ failed
Dec 12 17:07:48 DietPi gmediarender[649]: gst_element_link_pads_full: assertion ‘GST_IS_ELEMENT (src)’ failed
Dec 12 17:07:48 DietPi gmediarender[649]: gst_element_get_static_pad: assertion ‘GST_IS_ELEMENT (element)’ failed
Dec 12 17:07:48 DietPi gmediarender[649]: gst_element_link_pads_full: assertion ‘GST_IS_ELEMENT (dest)’ failed
Trying to dispose object “mixer”, but it still has a parent “(null)”.
You need to let the parent manage the object instead of unreffing the object directly.
Dec 12 17:07:48 DietPi dash[646]: Ready for rendering.
- DietPi version | DietPi v6.26.3
- Distro version | buster
- Kernel version | Linux DietPi 4.19.75-v7l+ #1270
- SBC device | RPi4 + DigiOne SPDIF board
- Power supply used | (Ciaudio 5V)
- SDcard used | (EG: SanDisk ultra)
