Hello.
I installed today for the first time Dietpi on a thinclient to control a 3D printer with Octoprint.
Now the boot process is heavily delayed by a job.
“a start job is running for ifup for eth0”.
Do I need this?
Thanks
This is your network interface. It seems taking quite long to get it up and to have an IP address assigned. Does it finish at some point?
Thanks for the answer.
Yes, it stops after approx. 1m13s.
Then it boots normally.
Only a USB wifi stick is connected
You can than deactivate your eth0 interface with dietpi-config because you’re not using it.
Perfect. Many Thanks.
I know it’s an old post, but, I’m facing this issue.
Is there any way to lower the time or disable the check completely? I’m doing a special build using dietpi for a PlayStation 4 Jailbreak. The jailbreak script exploits the ppoe protocol trough a cable connection between the device and PS4 and I need the network interface enabled for the script to work.
Can you check systemctl status dhcpcd@eth0.
Not sure why it takes so long, maybe it waites for an IP assignment via DHCP? You could try and set the IP to static instead of dhcp.
can you check following
journalctl -u ifup*
Simply assign a static IP or disable the interface if not needed. Actually your system is waiting to receive an IP address via DHCP
It has an IP and like I said above the interface has to be enabled for what I’m using it. I just want to lower that time check to like 1-3 sec.
The job is running because it wait’s to get an IP via DHCP.
You say, it has an IP. If you configured a static IP but it waits for DHCP assingment then something is off here…
If you lower the time to 3 seconds it will abort and does not get any IP, I think.
Can you share
cat /etc/network/interfaces
as already said
HI,i have same problem,after modify dhclient.conf,i finally solve it.U can add timeout 10; retry 5; reboot 10; initial-interval 2; select-timeout 5;
in file ’ /etc/dhcp/dhclient.conf’,it reduce half time. if u want to less time,you can decrease the number.
After i read the ifup* log ,i finally find the reason.
It take 1 min to get the IP,because it retry several times
This usually means that your device is not assigned an IP by the DHCP server. Otherwise there would be no retries.
Yes, ifup@eth0.service takes 1 minute only happens when I don’t plug in the network cable. If I plug in the router, it can get the IP address very quickly. But sometimes my device needs to plug in the network cable, and sometimes it doesn’t. Network cable, I hope whether or not the network cable is plugged in will not affect my startup speed.
yes this is expected behavior
Did you test if this dietpi-config option makes a difference or not?
Boot wait for network : [On]
i tested,this config option not affect ifup@eth0.service.
ok thx
