8" Touch Screen maps every input to lower right corner
  • DietPi version | 10.4
  • Distro version | trixie
  • Kernel version | 6.18.29-current-sunxi64
  • Architecture | arm64
  • SBC model | PINE A64 (aarch64)
  • Power supply used | RPi 5V 1A
  • SD card used | Samsung Evo
  • Software: Kiauh, Klipperscreen, HelixScreen, xcalibrate, xinput-calibrator (fresh installs)
  • Hardware: Elecrow 8" HDMI-Touchscreen DIS85801D
  1. Connect touchscreen with hdmi and usb.
  2. Install KIAUH via git clone
  3. Install either Klipperscreen or Helixscreen via KIAUH
  4. reboot
  • Klipperscreen or Helixscreen should respond to touch inputs .
  • No apparent reaction from any GUI element to touch input regardless where I touch the screen.
  • The issue started after I updated to dietpi 10.4.
  • I found that I can wake up the screen by touch. I connected it to my windows machine and it worked fine using the same cables I used for my SBC.
  • I tried recalibration using xinput-calibrator and xcalibrate. Both showed that every touch is mapped to the right lower corner. But no matter what, both tools weren’t able to change this behaviour.
  • I also tried Elecrow’s guide. But I can’t find config.txt. It’s not in /boot and I don’t have /boot/firmware.
I’m at the brink of pulling my hair. Help would be greatly appreciated.
config.txt only exists on raspberry pi.
Can you share the guide you are talking about?
Oh that’s why I can’t find config.txt. I was starting to question my installation…
You can find that guide here: 8 inch Touchscreen IPS Display 1280x800 Small Portable Monitor Compatible with Raspberry Pi 540043 Win 111087 Jetson Nano - Elecrow Wiki
(just after the pictures showing how to mount a Rpi to the back of the screen).
I also read a thread on the arch forums ( [SOLVED] Touchscreen not working / Newbie Corner / Arch Linux Forums ) and verified that the touch screen is correctly recognized (and not as a generic device or a graphic tablet).
Can you share
xinput list
Sure:
dietpi@OctoPine:~$ DISPLAY=:0 xinput list
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ dw_hdmi id=7 [slave pointer (2)]
⎜ ↳ QDtech MPI1001 Touchscreen id=6 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ axp20x-pek id=8 [slave keyboard (3)]
↳ dw_hdmi id=9 [slave keyboard (3)]
Okay can you also check
DISPLAY=:0 xinput list-props 6
And then test the screen, execute
DISPLAY=:0 xinput test 6
and touch it in different places. You should see different values. If you always see the same, then it’s probably a kernel/driver issue
Here are the touch screen’s props:
Device ‘dw_hdmi’:
Device Enabled (129):   1
Coordinate Transformation Matrix (130): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
libinput Natural Scrolling Enabled (251):       0
libinput Natural Scrolling Enabled Default (252):       0
libinput Scroll Methods Available (253):        0, 0, 1
libinput Scroll Method Enabled (254):   0, 0, 1
libinput Scroll Method Enabled Default (255):   0, 0, 1
libinput Button Scrolling Button (256): 0
libinput Button Scrolling Button Default (257): 0
libinput Button Scrolling Button Lock Enabled (258):    0
libinput Button Scrolling Button Lock Enabled Default (259):    0
libinput Accel Speed (260):     0.000000
libinput Accel Speed Default (261):     0.000000
libinput Accel Profiles Available (262):        1, 1, 1
libinput Accel Profile Enabled (263):   1, 0, 0
libinput Accel Profile Enabled Default (264):   1, 0, 0
libinput Accel Custom Fallback Points (265):
libinput Accel Custom Fallback Step (266):      0.000000
libinput Accel Custom Motion Points (267):
libinput Accel Custom Motion Step (268):        0.000000
libinput Accel Custom Scroll Points (269):
libinput Accel Custom Scroll Step (270):        0.000000
libinput Left Handed Enabled (271):     0
libinput Left Handed Enabled Default (272):     0
libinput Send Events Modes Available (273):     1, 0
libinput Send Events Mode Enabled (274):        0, 0
libinput Send Events Mode Enabled Default (275):        0, 0
Device Node (276):      “/dev/input/event1”
Device Product ID (277):        0, 0
libinput Drag Lock Buttons (278):
libinput Horizontal Scroll Enabled (279):       1
libinput Scrolling Pixel Distance (280):        15
libinput Scrolling Pixel Distance Default (281):        15
libinput High Resolution Wheel Scroll Enabled (282):    1
I couldn’t find any info on what the props for my device should be. I wonder why natural scrolling is disabled, but everything else seems in order. Did I overlook something?
I did
and I can see that some process started, but there is no verbose feedback in my SSH console.
Verbose output of xinput-calibrator:
dietpi@OctoPine:~$ DISPLAY=:0 xinput_calibrator -v
DEBUG: XInputExtension version is 2.4
DEBUG: Skipping virtual master devices and devices without axis valuators.
DEBUG: Skipping device 'Virtual core XTEST pointer' id=4, does not report Absolute events.
DEBUG: Skipping device 'dw_hdmi' id=7, does not report Absolute events.
DEBUG: Selected device: QDtech MPI1001 Touchscreen
DEBUG: Not usbtouchscreen calibrator: Not a usbtouchscreen device
DEBUG: Not evdev calibrator: Evdev: invalid "Evdev Axis Calibration" property format
Calibrating standard Xorg driver "QDtech MPI1001 Touchscreen"
        current calibration values: min_x=0, max_x=65535 and min_y=0, max_y=65535
        If these values are estimated wrong, either supply it manually with the --precalib option, or run the 'get_precalib.sh' script to automatically get it (through HAL).
DEBUG: Found that 'QDtech MPI1001 Touchscreen' is a sysfs name.
INFO: width=1280, height=800
DEBUG: Adding click 0 (X=1278, Y=798)
DEBUG: Not adding click 1 (X=1278, Y=798): within 7 pixels of previous click
I made click 0 on the first cross shown in the upper left part of the screen, and the next cross is shown in the upper right part. Every click is registered in the same spot.
Alright, the calibration is correct, it shows meaningful min and max values, but it always registers just one coordinate, no matter where you touch.
Can you make one last test, with evtest (You probably need to install it first: apt install evtest):slight_smile:
run sudo evtest and chose the correct device from the list, then just touch the dispaly as you did before. It will show us the raw kernel events. If the coordinates stay the same again then we know that it is a kernel/driver problem.
This is odd, it does not recogn
Oh wow i totally missed that. On the arch forums someone talked about how his touchscreen’s IDs weren’t listed in the kernel: [SOLVED] Touchscreen not working / Newbie Corner / Arch Linux Forums
Here is the output of evtest, I did four touches, each near a different corner.
dietpi@OctoPine:~$ sudo DISPLAY=:0 evtest
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0:      axp20x-pek
/dev/input/event1:      dw_hdmi
/dev/input/event2:      QDtech MPI1001 Touchscreen
Select the device event number [0-2]: 2
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x484 product 0x5750 version 0x101
Input device name: "QDtech MPI1001 Touchscreen"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 330 (BTN_TOUCH)
  Event type 3 (EV_ABS)
    Event code 0 (ABS_X)
      Value   1280
      Min        0
      Max     1280
    Event code 1 (ABS_Y)
      Value    800
      Min        0
      Max      800
    Event code 40 (ABS_MISC)
      Value      0
      Min        0
      Max        1
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
Properties:
Testing ... (interrupt to exit)
Event: time 1781128886.698273, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128886.698273, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1781128886.698273, type 3 (EV_ABS), code 0 (ABS_X), value 183
Event: time 1781128886.698273, type 3 (EV_ABS), code 1 (ABS_Y), value 146
Event: time 1781128886.698273, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1781128886.698273, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1781128886.698273, -------------- SYN_REPORT ------------
Event: time 1781128886.812222, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128886.812222, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1781128886.812222, -------------- SYN_REPORT ------------
Event: time 1781128887.455267, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128887.455267, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1781128887.455267, type 3 (EV_ABS), code 0 (ABS_X), value 1124
Event: time 1781128887.455267, type 3 (EV_ABS), code 1 (ABS_Y), value 156
Event: time 1781128887.455267, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1781128887.455267, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1781128887.455267, -------------- SYN_REPORT ------------
Event: time 1781128887.589223, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128887.589223, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1781128887.589223, -------------- SYN_REPORT ------------
Event: time 1781128888.274271, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128888.274271, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1781128888.274271, type 3 (EV_ABS), code 0 (ABS_X), value 234
Event: time 1781128888.274271, type 3 (EV_ABS), code 1 (ABS_Y), value 596
Event: time 1781128888.274271, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1781128888.274271, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1781128888.274271, -------------- SYN_REPORT ------------
Event: time 1781128888.418223, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128888.418223, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1781128888.418223, -------------- SYN_REPORT ------------
Event: time 1781128889.082272, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1781128889.082272, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1781128889.082272, type 3 (EV_ABS), code 0 (ABS_X), value 1064
Event: time 1781128889.082272, type 3 (EV_ABS), code 1 (ABS_Y), value 516
Ok good to know, at least this does not indicate any problem.
So the system gets the right coordinates, but then also gets the coordiantes for the bottom right corner, like you described. This is likely a scaling/calibration issue.
With the update to dietpi 10.4 you also udpated your kernel to mitigate the “Copy Fail” and “Dirty Frag” bugs?
And the display also runs in it’s native resolution?
Klipper does also provice some troubleshooting steps for a behaviour like you are experiencing:
https://klipperscreen.readthedocs.io/en/latest/Troubleshooting/Touch_issues/#touch-rotation-and-matrix
If I read the posts at Arch Forums correctly, this might lead to wrong drivers being loaded:
  1. the touchscreen manufacturer id (0x1ddb) and product id (0x1) are currently not into the usb vendors database (even after update-usbids)
  2. as such, the kernel (through udev) tried to discover the nature of it blind folded (i’d be interested to know on what basis), and ends up thinking that’s a tablet device (and not a touchscreen)
(From the last post in that thread.)
No I’v never explicitly updated the kernel. I only used apt upgrade or apt full-upgrade so far. How can do that?
Yes.
But in your case the kernel detects a touch device also with the correct resolution (see the evtest output)
When you did full-upgrade you installed the newest kernel (which is recommended to mitigate the CVEs).
You could try to downgrade the kernel for testing and see if it’s working again, but then you have a vulnerable system.
@MichaIng what do you think is the best to do here?
The guide you mentioned is explicitly for RPi, and cannot work anywhere else. The config.txt changes are only to enforce the correct (display) resolution, mode, and disable HDMI audio, along with some legacy options that are noops since a longer time, nothing which would affect touch input coordinates or so. There is a weird “driver” download listed, which however is no driver, but RPi-only config.txt files and scripts, basically this repo: GitHub - goodtft/LCD-show: 2.4" 2.8"3.2" 3.5" 5.0" 7.0" TFT LCD driver for the Raspberry PI 3B+/A/A+/B/B+/PI2/ PI3/ZERO/ZERO W · GitHub
Moreover, this is almost only for (smaller) DSI displays, some with I2C-attached touch. None of this is relevant for a HDMI display + USB touch. => That guide is crap, forget about it :smile:.
The Arch Linux thread is 14 years old, before the SBC era even started, and maybe a decade before your touchscreen was released. => Irrelevant :wink:.
The DietPi v10.4 v10.3 update implied the kernel upgrade from Linux 6.12 to 6.18, hence generally possible that this included some breaking change. But HDMI displays + USB touch inputs should not require any special drivers, but work mostly OOTB, after calibration.
xinput_calibrator should create a config below /etc/X11/. Check the configs there, /etc/X11/xorg.conf and everything below /etc/X11/xorg.conf.d in particular. Maybe there are some contradicting/conflicting ones. Maybe easiest to remove all of them (back them up somewhere). Then check again coordinates via evtest and/or touch input. If still wrong, run xinput_calibrator once. Check /etc/X11/ about which config file it generated, so we know the pattern. … IIRC it is /etc/X11/xorg.conf.d/99-calibration.conf.
If nothing helps, you can try to downgrade the kernel. But before you do, run these commands to protect your system against the Copy Fail, Dirty Frag, and Fragnesia vulnerabilities:
printf 'install algif_aead /bin/false\nblacklist algif_aead\n' | sudo tee /etc/modprobe.d/copyfail.conf
printf 'install esp4 /bin/false\ninstall esp6 /bin/false\ninstall rxrpc /bin/false\n' | sudo tee /etc/modprobe.d/dirtyfrag.conf
printf 'blacklist esp4\nblacklist esp6\nblacklist rxrpc\n' | sudo tee -a /etc/modprobe.d/dirtyfrag.conf
sudo modprobe -r algif_aead esp4 esp6 rxrpc
echo 3 | sudo tee /proc/sys/vm/drop_caches
Then:
apt install linux-{image,dtb}-current-sunxi64=26.02.0-trunk-dietpi8
This is the latest Linux 6.12, from March. We pushed the first Linux 6.18 kernel in early April, so DietPi v10.3 included it already. Did you upgrade to v10.4 from an earlier version than that? Else, it is unlikely that a Linux 6.18 patch release caused the issue :thinking:.
Thanks for the detailed walkthrough!
I can’t find any configs in /etc/X11:
dietpi@OctoPine:/etc/X11$ ls
app-defaults             fonts      rgb.txt     xinit  Xreset    Xresources  Xsession.d        Xwrapper.config
default-display-manager  ratpoison  xcalibrate  xkb    Xreset.d  Xsession    Xsession.options
But it seem they are stored in /usr/share/X11:
dietpi@OctoPine:/usr/share/X11$ ls
locale  rgb.txt  XErrorDB  xkb  xorg.conf.d
dietpi@OctoPine:/usr/share/X11/xorg.conf.d$ ls
10-amdgpu.conf  10-quirks.conf  10-radeon.conf  40-libinput.conf
I can’t use xinput_calbrator, because it won’t accept any of my input after the first touch, as they’re too close to each other. Strange enough, I can’t deactivate the threshold (–misclick 0).
dietpi@OctoPine:/usr/share/X11/xorg.conf.d$ DISPLAY=:0 xinput_calibrator -v
DEBUG: Adding click 0 (X=640, Y=400)
DEBUG: Not adding click 1 (X=640, Y=400): within 7 pixels of previous click
(I did the test after I used xcalibrate, which generated a matrix that maps all input to the middle of the screen)
I do wonder about that line:
Does that indicate something?
I used xcalibrate (GitHub - reinderien/xcalibrate: X.org touchscreen calibrator · GitHub) instead:
dietpi@OctoPine:~/xcalibrate$ DISPLAY=:0 ./xcalibrate
Pointer devices:
ID   Name
   4 Virtual core XTEST pointer
   6 QDtech MPI1001 Touchscreen
   7 dw_hdmi
Device to calibrate [6]:
Old calibration (Coordinate Transformation Matrix):
[[1. 0. 0.]
 [0. 1. 0.]
 [0. 0. 1.]]
Calibrate? [y]:
Point count (min 3) [4]:
Disable rotation and skew? [y]:
Warning: deficient transformation of rank 1. Please try calibrating again.
/home/dietpi/xcalibrate/./xcalibrate:258: RuntimeWarning: Mean of empty slice.
  quality = -np.log10(residuals.mean())
/usr/lib/python3/dist-packages/numpy/_core/_methods.py:145: RuntimeWarning: invalid value encountered in scalar divide
  ret = ret.dtype.type(ret / rcount)
New calibration:
[[0.24999969 0.         0.25039093]
 [0.         0.24999922 0.25062578]
 [0.         0.         1.        ]]
Quality (should be at least 3): nan
Test? [y]: y
Use calibration? [y]: y
The new calibration has been activated.
Write example xorg conf for persistence? [y]: y
To persist this calibration,
sudo mv 99-libinput-ts-calib.conf /usr/share/X11/xorg.conf.d/
dietpi@OctoPine:~/xcalibrate$ ls
99-libinput-ts-calib.conf  funding.md  license  readme.md  requirements.txt  xcalibrate
Contents of 99-libinput-ts-calib.conf:
# Generated by xcalibrate on 22/06/26 21:52:28
# https://www.x.org/releases/current/doc/man/man5/xorg.conf.5.xhtml#heading9
Section "InputClass"
    Identifier "QDtech MPI1001 Touchscreen touchscreen calibration"
    # For xinput device 6
    MatchDevicePath "/dev/input/event1"
    MatchProduct "QDtech MPI1001 Touchscreen"
    # For xinput property "Coordinate Transformation Matrix"
    Option "TransformationMatrix" "0.249999694347009 0 0.250390930175408 0 0.249999216794434 0.250625781247553 0 0 1"
EndSection
When testing with xcalibrate and the new matrix it seems like all touches are now mapped to the screen’s middle.
Then tested it with evtest:
dietpi@OctoPine:~/xcalibrate$ sudo DISPLAY=:0 evtest
Available devices:
/dev/input/event1:      QDtech MPI1001 Touchscreen
/dev/input/event2:      dw_hdmi
Select the device event number [0-2]: 1
Supported events:
      Value   1280
      Min        0
      Max     1280
      Value    800
      Min        0
      Max      800
      Value      0
      Min        0
      Max        1
Properties:
Event: time 1782158778.789760, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158778.789760, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1782158778.789760, type 3 (EV_ABS), code 0 (ABS_X), value 115
Event: time 1782158778.789760, type 3 (EV_ABS), code 1 (ABS_Y), value 110
Event: time 1782158778.789760, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1782158778.789760, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1782158778.789760, -------------- SYN_REPORT ------------
Event: time 1782158778.934706, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158778.934706, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1782158778.934706, -------------- SYN_REPORT ------------
Event: time 1782158779.189757, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158779.189757, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1782158779.189757, type 3 (EV_ABS), code 0 (ABS_X), value 604
Event: time 1782158779.189757, type 3 (EV_ABS), code 1 (ABS_Y), value 126
Event: time 1782158779.189757, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1782158779.189757, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1782158779.189757, -------------- SYN_REPORT ------------
Event: time 1782158779.324706, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158779.324706, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1782158779.324706, -------------- SYN_REPORT ------------
Event: time 1782158780.298760, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158780.298760, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1782158780.298760, type 3 (EV_ABS), code 0 (ABS_X), value 1048
Event: time 1782158780.298760, type 3 (EV_ABS), code 1 (ABS_Y), value 360
Event: time 1782158780.298760, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1782158780.298760, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1782158780.298760, -------------- SYN_REPORT ------------
Event: time 1782158780.463705, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158780.463705, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1782158780.463705, -------------- SYN_REPORT ------------
Event: time 1782158780.636756, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158780.636756, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 1
Event: time 1782158780.636756, type 3 (EV_ABS), code 0 (ABS_X), value 943
Event: time 1782158780.636756, type 3 (EV_ABS), code 1 (ABS_Y), value 146
Event: time 1782158780.636756, type 3 (EV_ABS), code 0 (ABS_X), value 1280
Event: time 1782158780.636756, type 3 (EV_ABS), code 1 (ABS_Y), value 800
Event: time 1782158780.636756, -------------- SYN_REPORT ------------
Event: time 1782158780.761705, type 4 (EV_MSC), code 4 (MSC_SCAN), value d0042
Event: time 1782158780.761705, type 1 (EV_KEY), code 330 (BTN_TOUCH), value 0
Event: time 1782158780.761705, -------------- SYN_REPORT ------------
Btw: How can I change my code to be highlighted like your’s? Sometimes it’s done automatically, sometimes not…
Also: Sorry for those long lines of code. Is there a way to collapse that so my post isn’t so bloated?
You.can define a language for each codeblock and based on this it will highlight automatically. See
Uhh, how come it makes such a false advice … /usr/share is for packages, not for custom admin or generated files. Those should go to /etc/X11/xorg.conf.d.
Maybe xinput_calibrator as well generates the file in the current dir, so you need to move it to /etc/X11/xorg.conf.d manually?
About the TransformationMatrix: xorg.conf(5) — xserver-xorg-core — Debian trixie — Debian Manpages
I know the "Calibration" option, which has 4 values only: min X, max X, min Y, max Y (while values can be swapped in case of axis swaps). But interestingly, I do not see this option in the manpage :thinking:.
Btw, did you
apt install xserver-xorg-input-evdev
And there is another touchscreen calibrator to test:
apt install x11-touchscreen-calibrator
Sorry for getting back to you so late. Life had some different plans so I hadn’t any time for my printer server :frowning:
Seems like both locations for that config do work.
Can’t test that because all clicks register at the same coordinate so xinput_calibrator won’t advance after the first click.
Yes I did that but it didn’t change anything.
Tried that and on github it says this one automatically adapts the Coordinate Transformation Matrix on resolution change, so I did
sudo DISPLAY=:0 xrandr -q
which oddly enough showed my display was in 1024x768 resolution:
dietpi@OctoPine:~$ sudo DISPLAY=:0 xrandr -q
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192
HDMI-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 1280mm x 800mm
   1280x800      63.59 +
   1920x1080     60.00
  1024x768 (0x43) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
I than did
sudo DISPLAY=:0 xrandr --output HDMI-1 --mode 1280x800
and
sudo DISPLAY=:0 xrandr --output HDMI-1 --mode 1920x1080
which both successfully changed the resolution (which btw I can’t using dietpi-config). The GUI then takes only a part of the screen but I still can’t calibrate the touch matrix to correctly register input. Also, I can’t change the resolution back to 1024x768.
I wonder if having an active 99-libinput-ts-calib.conf and may cause x11-touchscreen-calibrator to be unable to do the automatic configuration?. I will have a look at that tomorrow. It’s time for bed now :sleeping_face:
In any case, when testing different calibrators and re-calibration, remove any previously generated config file. Else they will most likely conflict. They configure things with different directives in different classes, IIRC.
Sure both works, else either package configs or admin config changes wouldn’t be effective. This is about FHS and Linux distro conventions, and how package managers deal with it: /usr is static dpkg territory, where packages add/remove/replace files without asking. /etc is admin territory, where packages place files as formal conffiles, which are never replaced, removed, or re-added, without interactive admin confirmation, if they were ever edited or manually removed. And /etc takes priority over /usr for files with the same name. This way you can override package configs, or mask them by placing a symlink to /dev/null with the same name into the respective /etc dir.
Sorry for coming back so late again. Life keeps getting in the way of my 3d printing hobby.
I made sure to delete the configs of one calilbrator before using the other - still no success.
I remember I tried an alternative to Klipperscreen called Helixscreen. I thought it didn’t respond to touch input, but maybe it was just the same symptoms I have now? I fully deleted Helixscreen and tried looking for any leftovers - couldn’t find anything. I’ll ask the dev if he has any insights, but - by any chance - do you have an idea where to look for changed input configuration?
I also found this calibrator: GitHub - ivan-matveev/xorg_calibrator: Touch screen calibration utility for X.Org X Window System · GitHub but it seems to be made for x64 architecture only.
Also Klipperscreen allows to use Wayland instead of Xserver. I tried Wayland with Cage as compositor, but the screen stayed black. Is Wayland a path to pursue or is that a dead end on DietPi?
See the man page about which files and directories X11 parses. For drop-in configs, /usr/share/X11/xorg.conf.d and /etc/X11/xorg.conf.d. Only the latter should contain custom configs, but as of all false guides and readmes, makes sense to check /usr/share/X11/xorg.conf.d too. If unsure whether a config is from a package or not, check with
dpkg -S <file path>
This will list any package which provides that path.
And a single pre-release shortly after the initial upload 3 years ago only. Doesn’t look trustworthy and has been abandoned. I wouldn’t use it.
Not yet supported by dietpi-software. You can use it, but deskop environments and other GUI applications installed with dietpi-software ship with X11 setup only. There should be however guides around how to setup a particular desktop environment with Wayland, that work on any Debian/Ubuntu-like distro. Both windowing systems can work side by side, so if properly configured, you can start a desktop/application with either of them.
