I am using DietPi on my Odroid C2. For the last two weeks I have been trying to boot from the SD card and use the root file system from the SSD, as the SD card is not as stable as an SSD.
I can’t set it up properly. I tried many options in the dietpiEnv.txt and armbianEnv.txt (I used Armbian before) and tested many options in the fstab - nothing worked.
Now I found the reason.
If I set the boot configuration (dietpiEnv.txt) and the fstab file on the SD card correctly, the SSD is used as root.
BUT:
I need a trick:
When I start the odroid, the boot window appears. It shows many command lines and everything works. THE ERROR starts when it says:
Loading Kernel...
Suddenly the screen goes black for a short time and reappears. Now no more USB devices are found. All devices that were previously recognized are lost. I have to plug in the USB connection again, and then the SSD is recognized again and the boot process is completed.
If I am not fast enough after loading the kernel, it does not work because the connected USB device is not found.
Do you have any idea?
Thank you very much!!!
Translated with DeepL.com (free version)
