that is one of the other adapters i tried out and returned as it didnt work for me. it would constantly disconnect… probably due to defects though. it looks like its showing up but not as 2.5gbs.
It’s eth1. Unfortunately our tools did not support 2 ethernet adapter directly. Therefore you would need to configure the eth1 adapter manuall, using a drop in configuration file at /etc/network/interfaces.d/
I created the file and I can ping on the IP address but when I unplug the onboard NIC I dont get a connection and when I unplug the USB NIC I can still ping it.
It seems that the IP address is on the onboard NIC.
ip a shows:
inet6 ::1/128 scope host noprefixroute
link/ether d8:3a:dd:e7:67:78 brd ff:ff:ff:ff:ff:ff
inet 192.168.0.254/24 brd 192.168.0.255 scope global eth0
inet6 xxxx:xxx:xxxx:x:xxxx:xxxx:xxxx:xxxx/64 scope global dynamic mngtmpaddr
valid_lft 46388sec preferred_lft 46388sec
inet6 fe80::da3a:ddff:fee7:6778/64 scope link
3: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether 6c:1f:f7:1b:a2:0f brd ff:ff:ff:ff:ff:ff
inet 192.168.0.249/24 brd 192.168.0.255 scope global eth1
inet6 xxxx:xxx:xxxx:x:xxxx:xxxx:xxxx:xxxx/64scope global dynamic mngtmpaddr
inet6 fe80::6e1f:f7ff:fe1b:a20f/64 scope link
Are you able to paste or screen shot where you are seeing this? 192.168.0.254 is the IP of eth0 I dont see any gateways shown in the “ip a” command output.
