4
111991
29 October 2023
Suggested terminal programs for dietpi (raspberry pi3, No graphical desktop)
0
10
20 April 2024
Late update to Bullseye / Lighty Issue [Solved]
1
28
19 April 2024
How do I install a .deb file on my Dietpi?
11
32
19 April 2024
Zigbee2MQTT and Home Assistant
0
22
19 April 2024
App ideas for dietpi-software
4
46
19 April 2024
How can I auto launch Chromium on system reboot
3
39
19 April 2024
Update Portainer to 2.20
6
74
19 April 2024
0
38
18 April 2024
[SOLVED] Autossh in custom.sh works when invoked directly, but not on boot
1
37
18 April 2024
External HDD has gone awol and sd card full
4
42
18 April 2024
Plex Media Server Remote Access Problem
0
34
18 April 2024
How to solve Transmission or Delugeaccess denied access to external HD?
16
87
18 April 2024
Can only access DietPi on SSH all other access blocked after fresh install
3
33
17 April 2024
Connection failed Wireguard VPN
2
37
17 April 2024
Backup and so on
3
52
17 April 2024
PXE boot (iVentoy) with Adguard Home (DHCP) and Unbound problem
10
208
17 April 2024
Upgrade to bookworm via script fails because of dkms and manually installed wireguard
2
82
17 April 2024
Alternative high current regulated 5vdc power supply for SBC's
0
32
17 April 2024
Mini UPS 5V and ~2A actually working for 3$
13
399
17 April 2024
10
133
16 April 2024
Owncloud not reachable anymore
56
293
16 April 2024
Baikal update failed
10
66
16 April 2024
Unable to interface with DietPi over personal VPN
1
50
16 April 2024
Maybe some self-hosted bot software for Discord
1
64
16 April 2024
Nexcloud login not working after updating DietPi v9.2.1
8
107
15 April 2024
Unbound: solution for communications error
9
73
15 April 2024
LMS update error
16
159
15 April 2024
DietPi + Odroid n2+ UART not working - how to enable?
81
3347
14 April 2024
Remove old Kernel's
12
78
14 April 2024
