4
111938
29 October 2023
PXE boot (iVentoy) with Adguard Home (DHCP) and Unbound problem
9
177
16 April 2024
Owncloud not reachable anymore
56
268
16 April 2024
Baikal update failed
10
51
16 April 2024
Unable to interface with DietPi over personal VPN
1
22
16 April 2024
Upgrade to bookworm via script fails because of dkms and manually installed wireguard
1
8
16 April 2024
Maybe some self-hosted bot software for Discord
1
58
16 April 2024
Mini UPS 5V and ~2A actually working for 3$
12
368
16 April 2024
Nexcloud login not working after updating DietPi v9.2.1
8
99
15 April 2024
Unbound: solution for communications error
9
61
15 April 2024
8
114
15 April 2024
LMS update error
16
142
15 April 2024
DietPi + Odroid n2+ UART not working - how to enable?
81
3300
14 April 2024
Remove old Kernel's
12
62
14 April 2024
RPI kernel update to 6.6
1
60
14 April 2024
Tinker Board rev 1.2 not booting / Image
5
56
14 April 2024
DietPi - NextCloud installation with parameters
2
44
14 April 2024
PiVPN Release v4.6.0: The end
8
140
14 April 2024
Node RED and MQTT
1
35
14 April 2024
External HDD turns read-only
9
71
13 April 2024
Setting up Diet Pi for my Raspbery Pi Zero 2W
2
51
12 April 2024
XZ Utils backdoor vulnerability, identified by CVE-2024-3094
3
167
12 April 2024
RPi3B - Upgraded from dietpi 8.5 to 9.2.1, stuck on kernel 5.10?
8
143
14 April 2024
Can i install dietpi on zimablade?
3
36
12 April 2024
Update Portainer to 2.20
5
57
12 April 2024
Alsa Mixer MAX98357
0
25
12 April 2024
Orange pi 3b NVME problem
30
157
12 April 2024
Is a dual boot with SSD and SD possible?
4
431
11 April 2024
Help in configuration my K3s cluster with Nanopi Fire 3
9
123
11 April 2024
Another trial image of unofficial DietPi - Radxa Zero 3W
2
133
11 April 2024
