[Solved] unable to connect through VNC Topic is solved
ghezzia
Re: unable to connect through VNC
Post by ghezzia »
Thanks a lot (again) for the support.
Now everything works great ;) .
Just a question: Does VNC start alone every time I reboot the system? Or should I manually restart it?
it should start automatically on reboot.
