Update DietPi from v7.4.2 to v7.8.2 keeps failing Topic is solved
Re: Update DietPi from v7.4.2 to v7.8.2 keeps failing
Indeed:
rm /etc/apt/sources.list.d/ntop.list
apt update
And if you want to update it:
cd /tmp
curl -fLo ntopng.deb 'https://packages.ntop.org/debian/buster_pi/armhf/ntopng/ntopng_5.1.211114-15936_armhf.deb'
dpkg -i ntopng.deb
rm ntopng.deb
Find the latest Raspberry Pi Buster packages here: https://packages.ntop.org/debian/buster ... hf/ntopng/
