Issue installing on HPT620 SSD Topic is solved
Re: Issue installing on HPT620 SSD
It is safe to remove the old kernel, when you reboot directly. I suggest to do:
apt purge linux-image-5.10.0-8-amd64
reboot
And confirm to remove to running kernel.
I'll update our x86_64 images to not contain a dedicated boot partition. This causes more issues than it solves, especially when no single kernel package is used like on RPi but a meta package, so that multiple kernel versions + related initramfs can be installed concurrently. RPi doesn't even use an initramfs by default, so there it is not an issue.
TommySharpNZ
Post by TommySharpNZ »
Thanks for looking into this guys.... In my machine's current state... What commands or steps should I be doing to resolve the issue? Or is it better just wait for a possible new image without the dedicated boot partition?
try this as stated above
reboot
TommySharpNZ
Thanks! running that appears to resolve the issue.... I will continue and hopefully this doesn't bite me in the ass months down the track and I have to rebuild :-)
At least the solution will always be the same. When you install a new kernel and the space in /boot isn't sufficient for some step, either remove the old kernel files manually (the initrd should always be sufficient as it is by far the largest file) or purge the old kernel package, then dpkg --configure -a and reboot.
