After upgrade to Bullseye - can't access Docker containers from browser Topic is solved
trendy
Re: After upgrade to Bullseye - can't access Docker containers from browser
Post by trendy »
I don't see anything blocked:
[4:256] -A DOCKER ! -i docker0 -p tcp -m tcp --dport 9002 -j DNAT --to-destination 172.17.0.2:9000
[4:256] -A DOCKER -d 172.17.0.2/32 ! -i docker0 -o docker0 -p tcp -m tcp --dport 9000 -j ACCEPT
4 packets were redirected from port 9002 to 9000 and they were also accepted by the firewall.
gyusza
Post by gyusza »
Thanks a lot @trendy, @Joulinar - it seems like something specific to my setup then...
I think i'll just do a fresh install and wont keep you digging!
Gyusza
trendy
Post by trendy »
Sorry I couldn't be of any more help here.
