Upgrade to Bullseye fails on Pi-hole reinstall Topic is solved
Niaz
Re: Upgrade to Bullseye fails on Pi-hole reinstall
Post by Niaz »
Yeah, I had there some ports specifications.
It was long overdue to redo it, but since it's just testing environment, I never forced myself to actually do it. :)
It's done now, and should be update proof for future. :D
