CPU temp at 122c
Re: CPU temp at 122c
We simply read the temperature from /sys/class/hwmon/hwmon0/temp1_input. That's what is reported by your system. Nothing more. Probably the other tool using a different value.
Also note that core temperatures can change quite quickly, also when only running the commands to read the temperature. To reduce overhead, after neofetch try to immediately execute either:
cat /sys/class/hwmon/hwmon0/temp1_input
or
G_OBTAIN_CPU_TEMP
Darron
Post by Darron »
Thank you guys for trying to sort this out, but ...
root@Server:~# cat /sys/class/hwmon/hwmon0/temp1_input
32850
root@Server:~# G_OBTAIN_CPU_TEMP
43
root@Server:~#
Two different commands two different temperatures, and that's not counting nefetch which is reporting another:
CPU: AMD Ryzen 5 1600 (12) @ 3.200GHz [26.6°on]
Then I installed lm-sensors:
32850
42
root@Server:~# sensors
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1:        +42.0°C
nvme-pci-0100
Adapter: PCI adapter
Composite:    +32.9°C
k10temp-pci-00c3
Tctl:         +25.5°C
Tdie:         +25.5°C
CPU: AMD Ryzen 5 1600 (12) @ 3.200GHz [25.7°on]
It makes me curious though, how can I feed the Tctl or Tdie sensors back to your MOTD? So instead of 42c it reports Tdie?
I'm sorry for the hassle, it's really not important, but it's just a bit of an annoyance and it'd be nice to have some parity.
You can find the /sys file which matches this temperature and put it to the top of the list in the mentioned /boot/dietpi/func/dietpi-globals script. To update the function for the current shell session:
. /boot/dietpi/func/dietpi-globals
It seems like 42°C is the WiFi adapter? Hotter than the CPU, strange :?.
Darron
Post by Darron »
MichaIng wrote: Fri Nov 19, 2021 3:06 pm You can find the /sys file which matches this temperature and put it to the top of the list in the mentioned /boot/dietpi/func/dietpi-globals script. To update the function for the current shell session:
Want to hear something really strange? I've disabled it!
Confusing :o. I dream of a world where every kernel/firmware/manufacturer uses the same sysfs files to provide CPU temperatures, same as optionally GPU and mainboard chip temperatures, those for HDDs/storage etc :D. Not sure how to proceed with this. For x86 as said it is difficult/expensive to differentiate between individual hardware. Easiest would be to allow defining a custom sysfs path to read. I just don't like that this would mean to run another sed on every function call. Probably we can load it as environment variable as part of dietpi-globals :?.
