Upgrade to Bullseye from Buster DietPi - PI Topic is solved
Salty Wagyu
Re: Upgrade to Bullseye from Buster DietPi - PI
Post by Salty Wagyu »
MichaIng wrote: Tue Nov 16, 2021 1:28 am For the GPU core clock, could you run this command again after a stress test on another SSH screen? All frequencies are scaled together with the CPU, hence the frequency you saw was likely in a near idle mode.
Probably all maximum frequencies can also be seen via:
vcgencmd get_config int
Sure, here's the output while stress test (cpu & ram) was running in another screen:
aaron@DietPi:~$ sudo vcgencmd measure_clock core
frequency(1)=500000992
aaron@DietPi:~$ sudo vcgencmd get_config int
arm_64bit=1
arm_boost=1
arm_freq=1800
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=500
core_freq_min=200
disable_commandline_tags=2
disable_l2cache=1
disable_overscan=1
disable_splash=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
dvfs=3
enable_gic=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_depth=16
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=500
gpu_freq_min=250
init_uart_clock=0x2dc6c00
initial_turbo=20
lcd_framerate=60
max_framebuffers=-1
over_voltage_avs=-20000
pause_burst_frames=1
program_serial_random=1
temp_limit=75
total_mem=4096
hdmi_force_cec_address:0=65535
hdmi_force_cec_address:1=65535
hdmi_pixel_freq_limit:0=0x11e1a300
hdmi_pixel_freq_limit:1=0x11e1a300
Okay, so it is only the CPU frequency which was raised. GPU runs at default frequency: https://www.raspberrypi.com/documentati ... erclocking
Good to know that this seems to run stable now without overvoltage. Our profile which matches these frequencies still applies +2 overvoltage. Looks like this can be enhanced a little to reduce power consumption = head dissipation :).
