Bullseye update fine but lighttpd is failing Topic is solved
Re: Bullseye update fine but lighttpd is failing
there you have the duplicate configuration for port 443 as it is defined in
/etc/lighttpd/conf-enabled/10-ssl.conf
/etc/lighttpd/conf-available/50-dietpi-https.conf
10-ssl.conf is a dummy configuration and it seems it got activate during update. I would recommend to remove
rm /etc/lighttpd/conf-enabled/10-ssl.conf
and check config again
/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
mcnahum
Post by mcnahum »
I think that we are progressing there...
root@DietPi:/mnt/RPiBackup/tst# rm /etc/lighttpd/conf-enabled/10-ssl.conf
root@DietPi:/mnt/RPiBackup/tst#  /usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
2021-11-11 14:43:58: configfile.c.461) Warning: "mod_compress" is DEPRECATED and has been replaced with "mod_deflate".  A future release of lighttpd 1.4.x will not contain mod_compress and lighttpd may fail to start up
2021-11-11 14:43:58: plugin.c.195) dlopen() failed for: /usr/lib/lighttpd/mod_deflate.so /usr/lib/lighttpd/mod_deflate.so: cannot open shared object file: No such file or directory
2021-11-11 14:43:58: server.c.1238) loading plugins finally failed
did you reinstall lighttpd after Bullseye upgrade? Usually our install will correct this on reinstall automatically.
mcnahum
Post by mcnahum »
no I didn't, I did multiple pihole -r / pihole -a ... but I didn't touched lighttps as it's coming with dietpi ...
any idea how to fix it?
try following
sed -Ei '/^compress\..*=[[:blank:]]*["(].*[")]$/d' /etc/lighttpd/lighttpd.conf
sed -i '/^[[:blank:]]*"mod_compress",$/d' /etc/lighttpd/lighttpd.conf
mcnahum
Post by mcnahum »
we are almost there:
2021-11-11 15:14:10: configfile.c.1142) WARNING: unknown config-key: setenv.add-environment (ignored)
So I started lighttps and .. yes it's active
The only issue now is going to https://pi-hole.mysite.net/admin/ give me a 404 Not Found instead of the Pihole web interface
That lighttpd.conf isn't the one from the Pi-hole installer but ours.
Actually we do a wrong migration in dietpi-software as we enable this 10-ssl.conf while dietpi-letsencrypt doesn't do it but includes these directives with the final/correct values. Here is the fix: https://github.com/MichaIng/DietPi/comm ... 822e44080c
Other migration steps are fine and still missing in your case:
apt install lighttpd-mod-deflate
lighty-enable-mod deflate
Ah setenv.add-environment is deprecated. I didn't know that. Something to fix in dietpi-letsencrypt to assure that the HTTPS variable is still set. However it should not break anything. What the hack, no hint about this in the official docs :?: https://redmine.lighttpd.net/projects/l ... _ModSetEnv
@MichaIng
I have seen the code line as well and was already going to ask about. Good you changed it already.
About the setenv warning, logs misinterpreted by me. The module is not loaded, fix it via:
G_CONFIG_INJECT '"mod_setenv"' '	"mod_setenv",' /etc/lighttpd/lighttpd.conf '"mod_.+",'
systemctl restart lighttpd
This is already done in dietpi-letsencrypt, so probably copy&pasting configs in attempt to solve things removed it, e.g. if the user from the Pi-hole forum didn't have HTTPS enabled ;).
