Docker compose Nginx Proxy Manager Topic is solved
Re: Docker compose Nginx Proxy Manager
as stated on the other forum post, if you go with a proxy software, you need to disable https on your web server hosting nextcloud and you need to change away from port 80 to 81. Your proxy will handle ssl and forward all request to nextcloud. usually it is not needed to have ssl active on any of your apps as all this should be handled by the proxy. Only thing you might need to check of your apps are able to work an a sub folder like
https://ddns.com/nextcloud
https://ddns.com/emby
https://ddns.com/plex
https://ddns.com/ombi
This way you would need a single certificate only. Usually your apps should have a wiki where it should describe how to use sub folder. Another option is to use sub domains. Something like this
https://emby.ddns.com
https://plex.ddns.com
You could mix it as well. All depends on your apps and how you could configure them
przemko
Post by przemko »
OK, thanks for help.
przemko
Post by przemko »
Hi, @Joulinar I think You're the only one who can help me :D
Please don't be mad.
I disable https on my Dietpi:
lighttpd-disable-mod dietpi-https dietpi-hsts dietpi-https_redirect
I uninstall certbot.
I forward ports on router like this:
external port:           host/IP           internal port:      protocol:
80-80                            192.168.0.19           8080-8080          TCP
443-443                        192.168.0.19           4443-4443          TCP
I install Nginx Proxy Manager like this:
version: '3'
services:
  nginx-proxy-manager:
    image: jlesage/nginx-proxy-manager
    network_mode: host
    volumes:
      - "/home/dietpi/.config/nginx-proxy-manager:/config:rw"
I change port for zigbee2mqtt:
 zigbee2mqtt:
    container_name: zigbee2mqtt
    restart: unless-stopped
    image: koenkk/zigbee2mqtt
    volumes:
      - ./zigbee2mqtt-data:/app/data
      - /run/udev:/run/udev:ro
    ports:
      - 8081:8080
    environment:
      - TZ=Europe/Berlin
    devices:
      - /dev/ttyUSB0:/dev/ttyUSB0
I install Petio:
version: "3"
networks:
  petio-network:
    driver: bridge
services:
  petio:
    image: ghcr.io/petio-team/petio:latest
    container_name: "petio"
    hostname: petio
    ports:
      - "7777:7777"
    networks:
      - petio-network
    depends_on:
      - mongo
    user: "1000:1000"
    environment:
      - TZ=Etc/UTC
    volumes:
      - /home/dietpi/.config/petio/config:/app/api/config
      - /home/dietpi/.config/petio/logs:/app/logs
  mongo:
    image: mongo:latest
    container_name: "mongo"
    hostname: mongo
    ports:
      - "27017:27017"
    networks:
      - petio-network
    user: "1000:1000"
    volumes:
      - /home/dietpi/.config/petio/db:/data/db
I remove also from my
/var/www/nextcloud/config/config.php
that /nextcloud :
'overwrite.cli.url' => 'https://myserver.ddns.net/nextcloud',
The strange situation is my Nextcloud works now on SSL but other apps don't.
Can You help me with that?
Regards
you would need to create a proxy definition for each application in NPM
przemko
Post by przemko »
Thanks, I also get some info that I need to make New Proxy Host for every app in NPM. I need to make subdomains on no-ip for every app like:
- homeassistant.myserver.ddns.net
- emby.myservernas.ddns.net
etc.
But I cannot find option in no-ip.com to make that subdomains. Do You know something about that?
Regards.
you can use sub folder as well on NPM. See my PM. Just search the web on how to use sub folder
przemko
Post by przemko »
But I get info from Home Assistant suppport that I cannot use subfolders for that :/
in this case you need to use sub domain for HA application
How to manage additional sub domain, maybe contact NoIP directly.
przemko
Post by przemko »
Thanks.
