Nextcloud Update & my current Webserver (Lighttpd)
Re: Nextcloud Update & my current Webserver (Lighttpd)
The issue with the redirects is a syntax error as you are missing the comma , behind each but the last redirect lines. Easiest is to copy&paste the configuration file I linked. The other two OCM/OCS provider redirects are not required with latest Nextcloud.
Disabling HTTPS won't work if HSTS was enabled before, at least not without using a different web browser or even OS. HSTS makes clients remember that the host is reachable via HTTPS and forces them to only accept HTTPS connections for the defined time, as security measure against DNS-wise attacks (e.g. letting the hostname resolve to a different server to steal your login credentials).
This is a Bullseye system, right?
Probably the combined cert+key file now needs to contain the full chain instead of the server certificate only. So the following could be tried:
cat '/etc/letsencrypt/live/MYDOMAIN/privkey.pem' '/etc/letsencrypt/live/MYDOMAIN/fullchain.pem' > '/etc/letsencrypt/live/MYDOMAIN/combined.pem'
Since Buster, Lighttpd does not require a combined cert+key file anymore but can apply them individually now. So further you could try this in /etc/lighttpd/conf-available/50-dietpi-https.conf:
Change:
	ssl.pemfile = "/etc/letsencrypt/live/MYDOMAIN/combined.pem"
	ssl.ca-file = "/etc/letsencrypt/live/MYDOMAIN/fullchain.pem"
to:
	ssl.pemfile = "/etc/letsencrypt/live/MYDOMAIN/fullchain.pem"
	ssl.privkey = "/etc/letsencrypt/live/MYDOMAIN/privkey.pem"
rubinski
Post by rubinski »
I am not sure about this ..
dietpi@DietPi:~$ uname -a
Linux DietPi 5.10.63-v7+ #1459 SMP Wed Oct 6 16:41:10 BST 2021 armv7l GNU/Linux
 DietPi v7.7.3 : 16:37 - Mon 11/08/21
 - Device model : RPi 3 Model B (armv7l)
echo $G_DISTRO_NAME
rubinski
Post by rubinski »
Thank you Guys!!
Just one simple Separator missing, or at the wrong place could be disastrous ... :)
dietpi@DietPi:/var/www/nextcloud/config$ echo $G_DISTRO_NAME
buster
P.S.:
Is is possible to have multiple Versions of Dietpi-Backups?
just if you create different backup folder. Can be done like this
  • dietpi-backup
  • Location
  • Manual
  • enter your new location inside /mnt/backup1.2.3.4.5.6...
  • <Ok>
  • <Cancel>
  • Backup
  • <Ok>
  • take a coffee
Here is a cron job example which maintains a choosable amount of backups on a daily basis: viewtopic.php?p=17321#p17321
maybe something for the docs :?
Or directly DietPi-Backup with next DietPi v7.9? Actually not a big deal to implement :?.
maybe we can talk about backups on our weekly call. :D
