Nextcloud Update & my current Webserver (Lighttpd)
Re: Nextcloud Update & my current Webserver (Lighttpd)
let's check configuration
/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
rubinski
Post by rubinski »
dietpi@DietPi:~$ /usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf
2021-11-04 22:44:51: (mod_openssl.c.445) SSL: BIO_read_filename('/etc/letsencrypt/live/MYDOMAIN/combined.pem') failed
2021-11-04 22:44:51: (server.c.1183) Initialization of plugins failed. Going down.
dietpi@DietPi:~$
this is pointing to issue with SSL configuration. could you share content of
ls -la /etc/letsencrypt/live/MYDOMAIN/
rubinski
Post by rubinski »
dietpi@DietPi:~$ sudo ls -la /etc/letsencrypt/live/MYDOMAIN
total 20
drwxr-xr-x 2 root root 4096 Oct  7 17:58 .
drwx------ 4 root root 4096 Sep 28  2020 ..
-rw-r--r-- 1 root root  692 Sep 28  2020 README
lrwxrwxrwx 1 root root   49 Oct  7 17:58 cert.pem -> ../../archive/MYDOMAIN/cert9.pem
lrwxrwxrwx 1 root root   50 Oct  7 17:58 chain.pem -> ../../archive/MYDOMAIN/chain9.pem
-rw-r--r-- 1 root root 5488 Nov  4 15:58 combined.pem
lrwxrwxrwx 1 root root   54 Oct  7 17:58 fullchain.pem -> ../../archive/MYDOMAIN/fullchain9.pem
lrwxrwxrwx 1 root root   52 Oct  7 17:58 privkey.pem -> ../../archive/MYDOMAIN/privkey9.pem
could you try running dietpi-letsencrypt again to recreate the certificate?
rubinski
Post by rubinski »
I did, but nothing has changed. Certificate Duration is until third of February.
Furthermore I have noticed, that there is another Folder at /etc/letsencrypt/live.
As far as I remember it has been created during another DynDNS attempt of mine (ddns.de). Should I delete that folder?
I am using the upper one.
DDNS has nothing to do with certificate creation. It doesn't matter how many DDNS you have. Inside /etc/letsencrypt/live you see all your certificate created. The last one was created back in September 2020 and certificate should be expired already. You should be able to remove all related folder/files inside /etc/letsencrypt/
Once cleaned up, using dietpi-letsencrypt 1 should force recreation of your current certificate.
rubinski
Post by rubinski »
Just to make sure that I do no mistake.
Inside /etc/letsencrypt I shall now delete all files/folders with (sudo) rm -rf and afterwards then dietpi-letsencrypt 1?
What I dont understand is, why this is a concern now, but not with Version 20.xx before.
Issue with web server is not related to NC as this is just a web app. Basically go inside each sub folder and remove stuff not needed.
rubinski
Post by rubinski »
Hmm.. I don´t really get it.
This is what I have planned to do:
sudo rm -rf /etc/letsencrypt/ and afterwards sudo dietpi-letsencrypt 1
Can you confirm this? Do I risk losing my SSH-Connection this way?
I am asking, because it is an Raspberry, which is not located at my house.
