Pi zero 2 W support Topic is solved
Re: Pi zero 2 W support
The ARMv8 image should work just the same way as the ARMv6 and ARMv7 images :?. You did enable WiFi in dietpi.txt + set SSID/WPA key in dietpi-wifi.txt?
ChurchOfNoise
Post by ChurchOfNoise »
Didn't need to, I connected a USB to LAN adapter.
The problem lies with the dtb file that is missing in the image (as per the link in my previous post), once I did that, all worked.
Adr3nal1n
Post by Adr3nal1n »
Thanks very much for the tip regarding the dtb file. I had the exact same issue with my headless rpi zero 2 w (connect via wifi) and now it is up and running on the 64 bit dietpi image.
issue with missing dtb file is already reported to RPi devs https://github.com/raspberrypi/Raspberr ... issues/189
Looks it's as expected at the moment.
The file could be download already https://github.com/raspberrypi/firmware ... zero-2.dtb
smithclarkson02
Post by smithclarkson02 »
So it appears that the Pi Zero 2 W is now available.
When can we expect a release that supports this particular (and slightly different) hardware configuration?
I
Need the same answer, Anyone?
Will be part of 7.8.
zackdvd
Post by zackdvd »
Hey,
did anyone of you tried bluetooth on the zero 2 w ? I tried with no success.
Can you check if its just me? Just updated to 7.8.1, but also no success on that.
viewtopic.php?t=9644
Thank you!
jason_a69
Post by jason_a69 »
Has there been a very new release to the kernel? My temperatures have dropped from close to 70C to about 45C.
DietPi themselves is just a set of bash scripts. We don't do any kernel development. This is done by the base OS. In your case a Raspberry OS. Means kernel is developed by RPI devs.
The_Raven
Post by The_Raven »
Joulinar wrote: Mon Nov 08, 2021 9:21 pm issue with missing dtb file is already reported to RPi devs https://github.com/raspberrypi/Raspberr ... issues/189
Walked in the same "trap". May be a hint on the download page would be nice ;)
Edit: Download and copy bcm2710-rpi-zero-2.dtb has NOT worked! Only copy and rename the bcm2710-rpi-3-b.dtb file worked for me!
