Pi zero 2 W support Topic is solved
CassTG
Re: Pi zero 2 W support
Post by CassTG »
So just a point of note, if i now want to do a fresh install because this device has more power under the hood i may do a docker setup instead of single app, i would download the fresh image and now switch the Tag to the dev branch as the zero branch has now been removed.
I presume the site will be updated on the download page when it's released official as the board is Arm7 and the current description states not for zero models. So if i want a fresh install now do i pick the ARm7 version and switch tags after initial install?
At best change the Git branch to "dev" already before first boot in dietpi.txt, to skip the doubled update. I did a lot of testing today, so related changes should be fine now. After initial setup, you can change the branch back to beta or master to get an update notification automatically, once a beta/master (stable) release is available.
Ah yes we need to update the info on the download page then. Not sure how to call the old ones then to make things clear, Raspberry Pi Zero 1? :?
Looks like we need to do this: https://github.com/MichaIng/DietPi-Website/issues/152
So that every architecture has its own tile to have more space listing the RPi models which support each image.
CassTG
Post by CassTG »
Thanks for that and yes makes sense on the homepage, will reflash shortly and follow that process
CassTG
Post by CassTG »
Followed the instructions, using Arm7 version, edit to dev and update, setup went smoothly, overclock profile applied okay, docker and btop running nicely, painless update process cheers
Only thing i noticed which may be correct i don't know
When setting overclock profile it also entered a setting for core_freq=500
I presume this is meant to go in the overclocking section of config.txt instead it was entered in the Serial/UART section, which may be the correct place but might just be a cosmetic issue as obviously it does not matter where it is.
The wrong settings location will be fixed with new RPi images. On first boot, erroneously an informational comment in the UART section was replaced by a commented setting. This was fixed with DietPi v7.5: https://github.com/MichaIng/DietPi/commit/60ebdf6
But the RPi images are v7.4 and this DietPi-FirstBoot script runs before the update ;).
Here was what should actually remain at that line: https://github.com/MichaIng/DietPi/blob ... ig.txt#L79
Crushed
Post by Crushed »
Arm7?
The chip of the Rpi Zero 2 is Arm8 , as far i saw...
ARM Cortex-A53
Computer processor
The ARM Cortex-A53 is one of the first two microarchitectures implementing the ARMv8-A 64-bit instruction set designed by ARM Holdings' Cambridge design centre. The Cortex-A53 is a 2-wide decode superscalar processor, capable of dual-issuing some instructions.
but it doesn't block you to run a ARMv7 or ARMv6 image ;)
CassTG
Post by CassTG »
Yep my logic to be fair was the ARMv8 dietpi version is 64bit only, as the unit doesent have oodles of ram and it's only running a few docker containers the 32bit version was sufficient enough for my use case and is running just fine
Just as a side note: using 32bit is not blocking you to use full 8GB memory on a RPi4B. ;)
ChurchOfNoise
Post by ChurchOfNoise »
I tried to get a fresh install going with the ARMv8 image yesterday, using 2 new Pi zero 2 W's and an USB to lan adapter.
For both RPI02Ws, after creating the SD card and adjusting the config (including changing the branch to beta), when I booted the RPI02Ws, they didn't appear on the network .
Given that they're headless, it's hard to problem solve.
Is there anything else I can do to ensure this works? (I could of course go for ARMv6 or v7 images, but given that I'm starting from scratch on these, I'd prefer to use the v8 image)
[Just to clarify: I've been running 2 DietPi installations on RPI Zero W with USB to LAN adapters for quite a while now, running Pi-Hole and compiled Unbound]
EDIT: just found the answer: https://qengineering.eu/install-64-os-o ... ero-2.html
