wireguard issue after upgrade Topic is solved
Re: wireguard issue after upgrade
systemd-resolved is not used, but resolvconf, which should be fine. openresolv is an alternative to resolvconf with more feature, but it sometimes has strange implications like restarting known local DNS resolvers whenever a new IPv6 RA is received, hence the features cause issues but nothing useful I'm aware of ;). Hence, I'd just leave it as it is.
Generally use journalctl -u wg-quick@Dietpi to debug issues with the WireGuard connection.
przemko
Post by przemko »
Hi, @MichaIng thanks for answer. Yesterday I turn off and on my Rpi and VPN works OK. I will check that command when it stops working.
Regards.
przemko
Post by przemko »
MichaIng wrote: Wed Nov 10, 2021 9:18 pm
No it stop working after reboot.
Linux DietPi 5.10.63-v7+
 DietPi v7.7.3 : 17:18 - Thu 11/11/21
 - Device model : RPi 3 Model B+ (armv7l)
 - CPU temp : 34'C : 93'F (Cool runnings)
 - LAN IP : 192.168.0.30 (eth0)
curl: (28) Resolving timed out after 3000 milliseconds
dietpi@DietPi:~$ sudo journalctl -u wg-quick@Dietpi
-- Logs begin at Thu 2021-11-11 17:17:02 CET, end at Thu 2021-11-11 17:19:06 CET. --
Nov 11 17:17:07 DietPi systemd[1]: Starting WireGuard via wg-quick(8) for Dietpi...
Nov 11 17:17:07 DietPi wg-quick[383]: [#] ip link add Dietpi type wireguard
Nov 11 17:17:08 DietPi wg-quick[383]: [#] wg setconf Dietpi /dev/fd/63
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip -4 address add 10.66.66.3/32 dev Dietpi
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip -6 address add fd42:42:42::3/128 dev Dietpi
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip link set mtu 1420 up dev Dietpi
Nov 11 17:17:08 DietPi wg-quick[383]: [#] resolvconf -a tun.Dietpi -m 0 -x
Nov 11 17:17:08 DietPi wg-quick[383]: Too few arguments.
Nov 11 17:17:08 DietPi wg-quick[383]: [#] wg set Dietpi fwmark 51820
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip -6 route add ::/0 dev Dietpi table 51820
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip -6 rule add not fwmark 51820 table 51820
Nov 11 17:17:08 DietPi wg-quick[383]: [#] ip -6 rule add table main suppress_prefixlength 0
Nov 11 17:17:09 DietPi wg-quick[383]: [#] ip6tables-restore -n
Nov 11 17:17:09 DietPi wg-quick[383]: [#] ip -4 route add 0.0.0.0/0 dev Dietpi table 51820
Nov 11 17:17:09 DietPi wg-quick[383]: [#] ip -4 rule add not fwmark 51820 table 51820
Nov 11 17:17:09 DietPi wg-quick[383]: [#] ip -4 rule add table main suppress_prefixlength 0
Nov 11 17:17:09 DietPi wg-quick[383]: [#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
Nov 11 17:17:09 DietPi wg-quick[383]: [#] iptables-restore -n
Nov 11 17:17:09 DietPi systemd[1]: Started WireGuard via wg-quick(8) for Dietpi.
dietpi@DietPi:~$
Regards.
and what is the status of the service?
przemko
Post by przemko »
dietpi@DietPi:~$ sudo systemctl status wg-quick@Dietpi
● wg-quick@Dietpi.service - WireGuard via wg-quick(8) for Di
etpi
   Loaded: loaded (/lib/systemd/system/wg-quick@.service; enabled; vendor preset: enabled)
   Active: active (exited) since Thu 2021-11-11 17:17:05 CET
; 2min 9s ago
     Docs: man:wg-quick(8)
           man:wg(8)
           https://www.wireguard.com/
           https://www.wireguard.com/quickstart/
           https://git.zx2c4.com/wireguard-tools/about/src/man/wg-quick.8
           https://git.zx2c4.com/wireguard-tools/about/src/man/wg.8
  Process: 379 ExecStart=/usr/bin/wg-quick up Dietpi (code=exited, status=0/SUCCESS)
 Main PID: 379 (code=exited, status=0/SUCCESS)
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -6 route add ::/0 dev Dietpi table 51820
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -6 rule add not fwmark 51820 table 51820
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -6 rule add table main suppress_prefixlength 0
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip6tables-restore -n
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -4 route add 0.0.0.0/0 dev Dietpi table 51820
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -4 rule add not fwmark 51820 table 51820
Nov 11 17:17:05 DietPi wg-quick[379]: [#] ip -4 rule add table main suppress_prefixlength 0
Nov 11 17:17:05 DietPi wg-quick[379]: [#] sysctl -q net.ipv4.conf.all.src_valid_mark=1
Nov 11 17:17:05 DietPi wg-quick[379]: [#] iptables-restore -n
Nov 11 17:17:05 DietPi systemd[1]: Started WireGuard via wg-quick(8) for Dietpi.
dietpi@DietPi:~$
and
dietpi@DietPi:~$ ping google.com
ping: google.com: Temporary failure in name resolution
dietpi@DietPi:~$
you could activate Wireguard debug logging
https://gist.github.com/artizirk/5bc87e ... 9e0436ef84
przemko
Post by przemko »
Hi, everything was fine until today I start actions in my Radarr panel. I refresh all indexers. Then my Dietpi stops again. I cannot connect with ssh and I must plug off from power supply. I noticed that when I don't use services on my Dietpi VPN tunnel works OK. I can connect and makes upgrades and other stuff.
