wireguard issue after upgrade Topic is solved
przemko
Re: wireguard issue after upgrade
Post by przemko »
No, I cannot connect with VPN tunnel. Also I have to plug off my Rpi to make it work because I cannot connect with ssh in local address.
Edit. Now even I disable wireguard I have internet test failture in dietpi-config.
Regards.
what do you mean you need to plug off the RPi? And pls put aside the internet connection test. Just do a simple ping to an internet address like google.com to see if it's working or not.
przemko
Post by przemko »
Hi, I disable wireguard, change DNS to google and I have internet working. Then I reinstall wireguard. First after reboot everything works super slow but after few minutes everything is working OK. I'm afraid after some time it will be broken again. I will ask for help then.
Regards.
przemko
Post by przemko »
Hi @Joulinar everything works great until today. I make some apt upgrade and after reboot my Dietpi stop working. I cannot ssh. I must plug off and then turn it on but wireguard not working. Also internet connections:
ping: google.com: Temporary failure in name resolution
Regards.
DNS doesn't seems to be working.
What DNS you are using?
cat /etc/resolv.conf
przemko
Post by przemko »
I set Google's DNS before reinstall wireguqrd and everything was OK
dietpi@DietPi:~$ cat /etc/resolv.conf
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
#     DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
nameserver 8.8.8.8
nameserver 8.8.4.4
dietpi@DietPi:~$
Is the Wireguard client active? If yes, stop it and try to ping google.com
przemko
Post by przemko »
Now I stop, disable wg-quick. Then start and everything works fine.
Looks like client was not connected correct. Probably it's starting too early before network is fully online.
przemko
Post by przemko »
Can I do something with that?
