wireguard issue after upgrade Topic is solved
Re: wireguard issue after upgrade
your issue is completely different @przemko as you are using client configuration on DietPi if I'm not mistaken.
do you see any handshake on server side?
przemko
Post by przemko »
That is strange, I see my client Dietpi3 in my WgDashboard as green(connected) and last handshake 0:0:51 sec ago but I cannot connect to it with vpn tunnel.
Regards.
are you able to ping VPN server address? Should be something like 10.x.x.1 I guess.
przemko
Post by przemko »
You mean ping from my Dietpi3?
Edit. Now I cannot even ssh to my Dietpi. It happen few times now.
yes ping from DietPi to wireguard server.
przemko
Post by przemko »
I try to:
ping http://5.183.210.11/
ping: http://5.183.210.11/: Name or service not known
and
ping http://10.66.66.1
ping: http://10.66.66.1: Name or service not known
przemko
Post by przemko »
But if I use ping function im my SSH browser i see:
PING 5.183.210.11 (5.182.210.11) 56(84) bytes of data.
64 bytes from 5.183.210.11: icmp_seq=1 ttl=64 time=34.7 ms
64 bytes from 5.183.210.11: icmp_seq=2 ttl=64 time=35.9 ms
64 bytes from 5.183.210.11: icmp_seq=3 ttl=64 time=34.1 ms
64 bytes from 5.183.210.11: icmp_seq=4 ttl=64 time=34.7 ms
--- 5.183.210.11 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 7ms
rtt min/avg/max/mdev = 34.058/34.851/35.934/0.704 ms
you can't ping a http web site. PING is working using ICMP and not http. Just use a IP address and not a protocol like http
could you try
ping 8.8.8.8
ping google.com
przemko
Post by przemko »
Yes I can:
dietpi@DietPi:~$ ping google.com
PING google.com (142.250.179.174) 56(84) bytes of data.
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=1 ttl=117 time=36.5 ms
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=2 ttl=117 time=34.9 ms
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=3 ttl=117 time=35.5 ms
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=4 ttl=117 time=35.9 ms
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=5 ttl=117 time=34.5 ms
64 bytes from ams15s41-in-f14.1e100.net (142.250.179.174): icmp_seq=6 ttl=117 time=34.9 ms
^C
--- google.com ping statistics ---
6 packets transmitted, 6 received, 0% packet loss, time 13ms
rtt min/avg/max/mdev = 34.518/35.370/36.539/0.707 ms
and VPN tunnel is active?
