4
111959
29 October 2023
External HDD has gone awol and sd card full
4
27
18 April 2024
[SOLVED] Autossh in custom.sh works when invoked directly, but not on boot
0
22
17 April 2024
Plex Media Server Remote Access Problem
0
12
18 April 2024
How to solve Transmission or Delugeaccess denied access to external HD?
16
75
18 April 2024
Can only access DietPi on SSH all other access blocked after fresh install
3
22
17 April 2024
Connection failed Wireguard VPN
2
21
17 April 2024
Backup and so on
3
45
17 April 2024
PXE boot (iVentoy) with Adguard Home (DHCP) and Unbound problem
10
198
17 April 2024
Upgrade to bookworm via script fails because of dkms and manually installed wireguard
2
54
17 April 2024
Alternative high current regulated 5vdc power supply for SBC's
0
24
17 April 2024
Mini UPS 5V and ~2A actually working for 3$
13
386
17 April 2024
10
129
16 April 2024
Owncloud not reachable anymore
56
286
16 April 2024
Baikal update failed
10
60
16 April 2024
Unable to interface with DietPi over personal VPN
1
44
16 April 2024
Maybe some self-hosted bot software for Discord
1
61
16 April 2024
Nexcloud login not working after updating DietPi v9.2.1
8
102
15 April 2024
Unbound: solution for communications error
9
67
15 April 2024
LMS update error
16
153
15 April 2024
DietPi + Odroid n2+ UART not working - how to enable?
81
3319
14 April 2024
Remove old Kernel's
12
73
14 April 2024
RPI kernel update to 6.6
1
67
14 April 2024
Tinker Board rev 1.2 not booting / Image
5
57
14 April 2024
DietPi - NextCloud installation with parameters
2
48
14 April 2024
PiVPN Release v4.6.0: The end
8
146
14 April 2024
Node RED and MQTT
1
36
14 April 2024
External HDD turns read-only
9
78
13 April 2024
Setting up Diet Pi for my Raspbery Pi Zero 2W
2
56
12 April 2024
XZ Utils backdoor vulnerability, identified by CVE-2024-3094
3
174
12 April 2024
