Updating DietPi has broken Nextcloud installation Topic is solved
gobstopper
Re: Updating DietPi has broken Nextcloud installation
Post by gobstopper »
root@DietPi:~# ls -la /usr/share/lighttpd/
total 28
drwxr-xr-x  2 root root 4096 Nov  6 15:10 .
drwxr-xr-x 89 root root 4096 Nov  6 16:07 ..
-rwxr-xr-x  1 root root 6139 Jan 27  2019 create-mime.conf.pl
-rwxr-xr-x  1 root root  462 Sep 27  2019 include-conf-enabled.pl
-rw-r--r--  1 root root 3388 Sep 27  2019 index.html
-rwxr-xr-x  1 root root  247 Sep 18  2020 use-ipv6.pl
ok let's try following
sed -i 's/create-mime\.assign\.pl/create-mime.conf.pl/g' /etc/lighttpd/lighttpd.conf
systemctl restart lighttpd.service
gobstopper
OK - that's got lighthttpd running again and I can hit the placeholder page. Great - thanks!
So, I think we're at the point you wanted to get to (which was to get the base distro upgraded to Buster) and then, if I recall, it was PHP next because if I try the /nextcloud page I get the internal server error message which started off this whole conversation.
let's check what version is installed
dpkg -l | grep 'php'
gobstopper
root@DietPi:~# dpkg -l | grep 'php'
ii  libapache2-mod-php8.0         8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        server-side, HTML-embedded scripting language (Apache 2 module)
ii  php                           2:8.0+84+0~20210621.36+debian9~1.gbp28513e                              all          server-side, HTML-embedded scripting language (default)
ii  php-apcu                      5.1.20+4.0.11-1+0~20210304.24+debian9~1.gbp1c3d4d                       armhf        APC User Cache for PHP
ii  php-common                    2:84+0~20210621.36+debian9~1.gbp28513e                                  all          Common files for PHP packages
ii  php-igbinary                  3.2.6+2.0.8-1+0~20210913.27+debian9~1.gbp64b0ea                         armhf        igbinary PHP serializer
ii  php-mysql                     2:8.0+84+0~20210621.36+debian9~1.gbp28513e                              all          MySQL module for PHP [default]
ii  php-pear                      1:1.10.12+submodules+notgz+20210212-1+0~20210228.21+debian9~1.gbpf2b98f all          PEAR Base System
ii  php-php-gettext               1.0.12-0.1                                                              all          read gettext MO files directly, without requiring anything other than PHP
ii  php-phpseclib                 2.0.14-1        all          implementations of an arbitrary-precision integer arithmetic library
ii  php-redis                     5.3.4+4.3.0-1+0~20210329.35+debian9~1.gbpdc7ead                         armhf        PHP extension for interfacing with Redis
ii  php7.3-cli                    7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        command-line interpreter for the PHP scripting language
ii  php7.3-common                 7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        documentation, examples and common module for PHP
rc  php7.3-curl                   7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        CURL module for PHP
ii  php7.3-fpm                    7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        server-side, HTML-embedded scripting language (FPM-CGI binary)
ii  php7.3-gd                     7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        GD module for PHP
ii  php7.3-intl                   7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        Internationalisation module for PHP
ii  php7.3-json                   7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        JSON module for PHP
ii  php7.3-mbstring               7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        MBSTRING module for PHP
ii  php7.3-mysql                  7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        MySQL module for PHP
ii  php7.3-opcache                7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        Zend OpCache module for PHP
ii  php7.3-readline               7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        readline module for PHP
ii  php7.3-xml                    7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        DOM, SimpleXML, WDDX, XML, and XSL module for PHP
ii  php7.3-zip                    7.3.31-1+0~20210923.88+debian9~1.gbpac4058                              armhf        Zip module for PHP
ii  php8.0                        8.0.11-1+0~20210923.24+debian9~1.gbp50d5dd                              all          server-side, HTML-embedded scripting language (metapackage)
ii  php8.0-apcu                   5.1.20+4.0.11-1+0~20210304.24+debian9~1.gbp1c3d4d                       armhf        APC User Cache for PHP
ii  php8.0-cli                    8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        command-line interpreter for the PHP scripting language
ii  php8.0-common                 8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        documentation, examples and common module for PHP
ii  php8.0-igbinary               3.2.6+2.0.8-1+0~20210913.27+debian9~1.gbp64b0ea                         armhf        igbinary PHP serializer
ii  php8.0-mysql                  8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        MySQL module for PHP
ii  php8.0-opcache                8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        Zend OpCache module for PHP
ii  php8.0-readline               8.0.10-1+0~20210826.23+debian9~1.gbp9ab3fd                              armhf        readline module for PHP
ii  php8.0-redis                  5.3.4+4.3.0-1+0~20210329.35+debian9~1.gbpdc7ead                         armhf        PHP extension for interfacing with Redis
ii  phpmyadmin                    4:4.6.6-5                                                               all          MySQL web administration tool
try following
apt purge '*php8.0*'
apt install php7.3-apcu php7.3-redis
gobstopper
Thanks again for your continued support on this.
I have run the commands and, as a precaution, rebooted the Pi. This appears to have killed lighthttpd again -
 DietPi-Services
âââââââââââââââââââââââââââââââââââââââââââââââââââââ
 Mode: status
[  OK  ] DietPi-Services | redis-server         active (running) since Sun 2021-11-07 17:42:59 GMT; 58s ago
[  OK  ] DietPi-Services | mariadb              active (running) since Sun 2021-11-07 17:43:01 GMT; 56s ago
[  OK  ] DietPi-Services | php7.3-fpm           active (running) since Sun 2021-11-07 17:43:02 GMT; 54s ago
[FAILED] DietPi-Services | â lighttpd.service - Lighttpd Daemon
   Loaded: loaded (/lib/systemd/system/lighttpd.service; disabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2021-11-07 17:43:06 GMT; 51s ago
  Process: 765 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=255/EXCEPTION)
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Service RestartSec=100ms expired, scheduling restart.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Scheduled restart job, restart counter is at 5.
Nov 07 17:43:06 DietPi systemd[1]: Stopped Lighttpd Daemon.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Start request repeated too quickly.
Nov 07 17:43:06 DietPi systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Nov 07 17:43:06 DietPi systemd[1]: Failed to start Lighttpd Daemon.
[  OK  ] DietPi-Services | cron                 active (running) since Sun 2021-11-07 17:43:03 GMT; 54s ago
[  OK  ] DietPi-Services | ssh                  active (running) since Sun 2021-11-07 17:42:58 GMT; 59s ago
[ INFO ] DietPi-Services | dietpi-vpn           inactive (dead)
[  OK  ] DietPi-Services | dietpi-ramlog        active (exited) since Sun 2021-11-07 17:42:47 GMT; 1min 10s ago
[  OK  ] DietPi-Services | dietpi-preboot       active (exited) since Sun 2021-11-07 17:42:47 GMT; 1min 10s ago
Warning: The unit file, source configuration file or drop-ins of dietpi-postboot.service changed on disk. Run 'systemctl daemon-reload' to reload units.
[  OK  ] DietPi-Services | dietpi-postboot      active (exited) since Sun 2021-11-07 17:42:58 GMT; 59s ago
[ INFO ] DietPi-Services | dietpi-wifi-monitor  inactive (dead)
Though it looks like php 7.3 has installed and is running.
Pls share
gobstopper
Happy to. Still very grateful for your continued assistance -
WARNING: include-conf-enabled.pl is deprecated and slated for removal.
         Replace in lighttpd.conf with:
           include "/etc/lighttpd/conf-enabled/*.conf"
2021-11-08 09:55:11: (configfile.c.1328) opening configfile  /etc/lighttpd/conf-enabled/50-phpmyadmin.conf failed: No such file or directory
2021-11-08 09:55:11: (configfile.c.1296) source: /usr/share/lighttpd/include-conf-enabled.pl line: 7 pos: 8 parser failed somehow near here: (EOL)
2021-11-08 09:55:11: (configfile.c.1296) source: /etc/lighttpd/lighttpd.conf line: 32 pos: 1 parser failed somehow near here: (EOL)
ah phpMyAdmin has been removed as well. Therefore config would need to be disabled
rm /etc/lighttpd/conf-enabled/50-phpmyadmin.conf
