Kodi Error - Kodi not starting Topic is solved
Re: Kodi Error - Kodi not starting
A reboot is required when the display driver is switched:
/boot/dietpi/func/dietpi-set_hardware rpi-opengl vc4-kms-v3d
reboot
# after reboot
startkodi
wmcig
Post by wmcig »
After reboot I tried to connect via ssh to the local machine. The following code was shown:
ssh root@192.168.178.40
ssh: connect to host 192.168.178.40 port 22: No route to host
I can not connect anymore.
Also the Pihole and Nginx Server are unreachable. This is not funny.
You have a screen that could be attached to see what happens?
wmcig
Post by wmcig »
Okay. Server works now.
startkodi
failed to open zone.tab
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.10.0
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
Screen shows only blank screen. Seems to be no connection from Kodi.
Did you already tried to set Kodi as autostart option? Do you have any HDMI output while the Pi is booting or is the screen staying black? Usually you should see the command line, even without Kodi. Isn't it?
wmcig
Post by wmcig »
I will try tomorrow.
wmcig
Post by wmcig »
Okay, I can now see Kodi on the screen.
How can I connect via the kodi remote app to Kodi app? Maybe I need a port number?
I researched a bit. Port 8080 should the right one? But the manually connection and the automatically connection not working.
This is because Kodi changed the default webserver settings to be more secure, and since v19 web server is disabled by default. You simply need to activate the web server settings to permit remote control and to access Kodi.
To do that go to Settings > Services > Control and either confirm that you want to allow external access to the web server without authentication and password (it will warn against this) or enter a password, and then enable allow remote control via HTTP.
wmcig
Post by wmcig »
Joulinar wrote: Wed Nov 24, 2021 1:20 pm This is because Kodi changed the default webserver settings to be more secure, and since v19 web server is disabled by default. You simply need to activate the web server settings to permit remote control and to access Kodi.
Where and how to do? I can not connect to Kodi via App remote.
connect a mouse to your Pi and use it to navigate in Kodi
