Kodi Error - Kodi not starting Topic is solved
Re: Kodi Error - Kodi not starting
yes, RPi devs did some development and on RPi4 64bit it was working on my test I did this week
wmcig
Post by wmcig »
Joulinar wrote: Thu Nov 18, 2021 11:53 am yes, RPi devs did some development and on RPi4 64bit it was working on my test I did this week
DietPi-Software
 Step: Install completed
[  OK  ] DietPi-Survey | Purging survey data
[ SUB1 ] DietPi-Services > restart
[  OK  ] DietPi-Services | restart : avahi-daemon
[  OK  ] DietPi-Services | restart : proftpd
[  OK  ] DietPi-Services | restart : php7.4-fpm
[  OK  ] DietPi-Services | restart : nginx
[  OK  ] DietPi-Services | restart : lighttpd
[  OK  ] DietPi-Services | restart : cron
root@DietPi:~# startkodi
-bash: startkodi: command not found
After reboot:
failed to open zone.tab
error: XDG_RUNTIME_DIR not set in the environment.
libva info: VA-API version 1.10.0
libva error: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
^C
Something is still wrong?
usually not. Kodi should start on an attached screen.
wmcig
Post by wmcig »
So I should use an HDMI cable from my Raspi to my TV and then I try the command again?
yes Kodi as an application that require a monitor. It's not something you could run on a SSH client.
Indeed, like all GUI applications. For X11, there is an X11 forwarding feature, which is by default enabled on OpenSSH as well as on Dropbear SSH servers, and which can be enabled on PuTTY. Then one needs to run a local X server on the client system, e.g. Xming on Windows. But I don't think passing a playing video through SSH will work at all, and the RPi Kodi build uses GBM/DRM and not the X server, so no chance.
wmcig
Post by wmcig »
So I can not use Kodi via Raspi 4 to my TV Screen with HDMI?
startkodi
I thought that the app would Start as media center on the Raspi.
of course you can use Kodi an a HDMI connected screen
wmcig
Post by wmcig »
Joulinar wrote: Tue Nov 23, 2021 10:52 am of course you can use Kodi an a HDMI connected screen
But I only have no kodi on my screen and the above error code in my terminal.
messages on console are ok. Try following
/boot/dietpi/func/dietpi-set_hardware rpi-opengl vc4-kms-v3d
startkodi
