Increase swap? Topic is solved
Re: Increase swap?
still think on a different device. Swapping is the worst think you could do.
kannz
Re: Increase swap?
Post by kannz »
I'm not really worried about performance but my friend let me borrow a rpi4 with his ZigBee USB gateway in case the C2 doesn't work right. Which I may try to just set it up with the rpi4 first then try an see how it goes with the C2.
