Increase swap? Topic is solved
Re: Increase swap?
simply execute the command I posted above and magic happen ;)
kannz
Re: Increase swap?
Post by kannz »
looks like it's increased to 1gb. Thank you
kannz
Re: Increase swap?
Post by kannz »
heyo comin back to this topic of mine. probably no real issue. I was wondering if the large amount of files i have sitting on my hdd is making dietpi use up a lot of ram as buff/cache?
Re: Increase swap?
It depends on how often files are used/accessed and which application is using them. Just because they are stored on a HDD, doesn't mean they are moved into memory.
kannz
Re: Increase swap?
Post by kannz »
hmm im using it for smb and pihole. also my samba share responds very quickly. how would i be able to tell if it is putting the hdd to sleep when not in use?
kannz
Re: Increase swap?
Post by kannz »
how do i tell how much memory is being taken by the gpu?
Re: Increase swap?
honestly I don't have a C2 as all my devices are RPi. On RPi it's configured inside config.txt
cat /boot/config.txt | grep gpu_mem
kannz
Re: Increase swap?
Post by kannz »
Says no such file or directory. Hmm looks like odroid has a dynamic gpu memory system. Doesn't use manual allocation apparently..it uses whatever memory is not used.
Re: Increase swap?
The Odroid C2 has a fixed amount of system memory reserved for the GPU. Check:
free -m
The difference of total memory to ~2000 MiB is what the GPU/VPU uses. You can disable it via dietpi-config > Display Options > GPU/RAM Memory Split, which will disable all video output but restores ~300 MiB RAM for the system.
It can be also changed manually via nographics setting in /boot/boot.ini.
kannz
Re: Increase swap?
Post by kannz »
thank you the small amount of extra memory may help use swap a little less. :)
