can't update. Cerificate errors
Re: can't update. Cerificate errors
Confusing that this is even an issue on Bullseye :?. Can you show the following:
dpkg -l | grep ssl
manilx
Post by manilx »
ii  libnet-ssleay-perl            1.88-3+b1                      amd64        Perl module for Secure Sockets Layer (SSL)
ii  libssl1.1:amd64               1.1.1k-1+deb11u1               amd64        Secure Sockets Layer toolkit - shared libraries
ii  libxmlsec1-openssl:amd64      1.2.31-1                       amd64        Openssl engine for the XML security library
ii  libzstd1:amd64                1.4.8+dfsg-2.1                 amd64        fast lossless compression algorithm
ii  openssl                       1.1.1k-1+deb11u1               amd64        Secure Sockets Layer toolkit - cryptographic utility
ii  perl-openssl-defaults:amd64   5                              amd64        version compatibility baseline for Perl OpenSSL packages
Could you try switching back to HTTPS pls. We got feedback from Debian System Administrators and issue should have been fixed. At least for their repository.
manilx
Post by manilx »
Tried again.
Debian seems fixed now. Webmin still gives error.
I guess something Webmin guys would need to fix, same way as Debian guys did
btw issue has been reported to webmin https://github.com/webmin/webmin/issues/1533
manilx
Post by manilx »
I've read the whole thread.
The issue here was the ssl inspection of our Fortigate (at newest firmware and fully updated).
It cancelled the connections due to the certificate issues.
We had to disable ssl inspection for the time being.
It is not only old Ubuntu etc installations but up to date firewalls.
As I don’t have a login to post there you might inform them.
Thx!
