Update not working / CA Issues / no Release File Topic is solved
Re: Update not working / CA Issues / no Release File
Ok try revert back to HTTPS and check if apt update is working still
henkb
Post by henkb »
Yep. Works as it should. Changed it right after the first update. :)
