mariadb not running
boogey
Re: mariadb not running
Post by boogey »
Thank you for the new information. I have started from scratch to be able to install the 64 bit version of dietpi. I think I had a bad first install as I got an error on cmd line about being in maintenance mode and needing to log in or some nonsense like that. Going to try reinstalling.
Will surely keep that scan command handy. I will still need that either way.
Thanks Joulinar
ok to bad you needed to start from scratch. Hope it gonna work at the end.
