Lighttpd SSL failures after upgrade from Buster to Bullseye Topic is solved
przemko
Re: Lighttpd SSL failures after upgrade from Buster to Bullseye
Post by przemko »
I purge mysql and alll folders. I don't see lighttpd and mariadb services and now when I try to install Nextcloud or Pydio I see error:
 [FAILED] File does not exist or cannot be written to by current user                                                 │
                                                               │ Please verify the existence of the file $3        │
                                                               │         /etc/lighttpd/lighttpd.conf        │
                                                               │ Retry with proper permissions or apply the setting manually:                                                         │
                                                               │         "mod_access",
I want to fresh install of Nextcloud. Can I fix that?
Regards.
did you run the uninstall via dietpi-software or did you just removed the folder?
przemko
Post by przemko »
OK I finally make fresh install. Thanks for Your time and help.
Regards.
ok at least it's working again now
