Lighttpd SSL failures after upgrade from Buster to Bullseye Topic is solved
przemko
Re: Lighttpd SSL failures after upgrade from Buster to Bullseye
Post by przemko »
The same errors as You see the versions of Mariadb is problem.
root@DietPi:/var/log/mysql# cat error.log
2021-10-09  9:35:15 0 [Note] InnoDB: Using Linux native AIO
2021-10-09  9:35:15 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-10-09  9:35:15 0 [Note] InnoDB: Uses event mutexes
2021-10-09  9:35:15 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-10-09  9:35:15 0 [Note] InnoDB: Number of pools: 1
2021-10-09  9:35:15 0 [Note] InnoDB: Using SSE2 crc32 instructions
2021-10-09  9:35:15 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-10-09  9:35:15 0 [Note] InnoDB: Completed initialization of buffer pool
2021-10-09  9:35:15 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2021-10-09  9:35:15 0 [ERROR] InnoDB: Unsupported redo log format. The redo log was created with MariaDB 10.5.11.
2021-10-09  9:35:15 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2021-10-09  9:35:15 0 [Note] InnoDB: Starting shutdown...
2021-10-09  9:35:16 0 [ERROR] Plugin 'InnoDB' init function returned error.
2021-10-09  9:35:16 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2021-10-09  9:35:16 0 [Note] Plugin 'FEEDBACK' is disabled.
2021-10-09  9:35:16 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2021-10-09  9:35:16 0 [ERROR] Aborting
2021-10-09  9:39:26 0 [Note] InnoDB: Using Linux native AIO
2021-10-09  9:39:26 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-10-09  9:39:26 0 [Note] InnoDB: Uses event mutexes
2021-10-09  9:39:26 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-10-09  9:39:26 0 [Note] InnoDB: Number of pools: 1
2021-10-09  9:39:26 0 [Note] InnoDB: Using SSE2 crc32 instructions
2021-10-09  9:39:27 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-10-09  9:39:27 0 [Note] InnoDB: Completed initialization of buffer pool
2021-10-09  9:39:27 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2021-10-09  9:39:27 0 [ERROR] InnoDB: Unsupported redo log format. The redo log was created with MariaDB 10.5.11.
2021-10-09  9:39:27 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2021-10-09  9:39:27 0 [Note] InnoDB: Starting shutdown...
2021-10-09  9:39:28 0 [ERROR] Plugin 'InnoDB' init function returned error.
2021-10-09  9:39:28 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2021-10-09  9:39:28 0 [Note] Plugin 'FEEDBACK' is disabled.
2021-10-09  9:39:28 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2021-10-09  9:39:28 0 [ERROR] Aborting
2021-10-09  9:39:40 0 [Note] InnoDB: Using Linux native AIO
2021-10-09  9:39:40 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-10-09  9:39:40 0 [Note] InnoDB: Uses event mutexes
2021-10-09  9:39:40 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-10-09  9:39:40 0 [Note] InnoDB: Number of pools: 1
2021-10-09  9:39:40 0 [Note] InnoDB: Using SSE2 crc32 instructions
2021-10-09  9:39:40 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-10-09  9:39:40 0 [Note] InnoDB: Completed initialization of buffer pool
2021-10-09  9:39:40 0 [Note] InnoDB: If the mysqld execution user is authorized, page cleaner thread priority can be changed. See the man page of setpriority().
2021-10-09  9:39:40 0 [ERROR] InnoDB: Unsupported redo log format. The redo log was created with MariaDB 10.5.11.
2021-10-09  9:39:40 0 [ERROR] InnoDB: Plugin initialization aborted with error Generic error
2021-10-09  9:39:40 0 [Note] InnoDB: Starting shutdown...
2021-10-09  9:39:41 0 [ERROR] Plugin 'InnoDB' init function returned error.
2021-10-09  9:39:41 0 [ERROR] Plugin 'InnoDB' registration as a STORAGE ENGINE failed.
2021-10-09  9:39:41 0 [Note] Plugin 'FEEDBACK' is disabled.
2021-10-09  9:39:41 0 [ERROR] Unknown/unsupported storage engine: InnoDB
2021-10-09  9:39:41 0 [ERROR] Aborting
I have idea to completly remove nextcloud, upgrade to Bullseye and then install nextcloud and move data folders to new installation.
Regards.
przemko
Post by przemko »
Hi @Joulinar Can I just upgrade Mariadb?
I just remove /dietpi_userdata/mysql folder and now I can reinstall nextcloud but it don't work also.
I see:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
on my https website. Http don't work also.
When I try to fix with ncc command I see those errors:
root@DietPi:/# ncc
An unhandled exception has been thrown:
PDOException: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php:82
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(82): PDO->query('SELECT * FROM `...')
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1035): Doctrine\DBAL\Driver\PDO\Connection->query('SELECT * FROM `...')
#2 /var/www/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#3 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(210): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#5 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#7 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#8 /var/www/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#9 /var/www/nextcloud/lib/private/Server.php(682): OC_App::getAppVersions()
#10 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#11 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#12 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#13 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#14 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(177): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#17 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#18 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#19 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#20 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#21 /var/www/nextcloud/lib/private/Server.php(1041): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#23 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#24 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#25 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#26 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#27 /var/www/nextcloud/lib/private/Server.php(2000): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Files/View.php(119): OC\Server->getLockingProvider()
#29 /var/www/nextcloud/lib/private/Server.php(430): OC\Files\View->__construct()
#30 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#31 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#32 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#33 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#34 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#35 /var/www/nextcloud/lib/private/Server.php(1363): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/base.php(588): OC\Server->boot()
#37 /var/www/nextcloud/lib/base.php(1076): OC::init()
#38 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#39 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#40 {main}
Next Doctrine\DBAL\Driver\PDO\Exception: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php:26
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Connection.php(87): Doctrine\DBAL\Driver\PDO\Exception::new(Object(PDOException))
#40 {main}
Next Doctrine\DBAL\Exception\TableNotFoundException: An exception occurred while executing a query: SQLSTATE[42S02]: Base table or view not found: 1146 Table 'nextcloud.oc_appconfig' doesn't exist in /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php:47
Stack trace:
#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1728): Doctrine\DBAL\Driver\API\MySQL\ExceptionConverter->convert(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1667): Doctrine\DBAL\Connection->handleDriverException(Object(Doctrine\DBAL\Driver\PDO\Exception), Object(Doctrine\DBAL\Query))
#2 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1040): Doctrine\DBAL\Connection->convertExceptionDuringQuery(Object(Doctrine\DBAL\Driver\PDO\Exception), 'SELECT * FROM `...', Array, Array)
#3 /var/www/nextcloud/lib/private/DB/Connection.php(226): Doctrine\DBAL\Connection->executeQuery('SELECT * FROM `...', Array, Array, NULL)
#4 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php(210): OC\DB\Connection->executeQuery('SELECT * FROM `...', Array, Array)
#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(287): Doctrine\DBAL\Query\QueryBuilder->execute()
#6 /var/www/nextcloud/lib/private/AppConfig.php(345): OC\DB\QueryBuilder\QueryBuilder->execute()
#7 /var/www/nextcloud/lib/private/AppConfig.php(110): OC\AppConfig->loadConfigValues()
#8 /var/www/nextcloud/lib/private/AppConfig.php(301): OC\AppConfig->getApps()
#9 /var/www/nextcloud/lib/private/legacy/OC_App.php(965): OC\AppConfig->getValues(false, 'installed_versi...')
#10 /var/www/nextcloud/lib/private/Server.php(682): OC_App::getAppVersions()
#11 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#12 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#13 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Memcache\\Fac...')
#14 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Memcache\\Fac...', false)
#15 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Memcache\\Fac...')
#16 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(177): OC\AppFramework\Utility\SimpleContainer->get('OC\\Memcache\\Fac...')
#17 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(OC\Server))
#18 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(114): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#19 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\ICacheFacto...')
#20 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\ICacheFacto...', false)
#21 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\ICacheFacto...')
#22 /var/www/nextcloud/lib/private/Server.php(1041): OC\AppFramework\Utility\SimpleContainer->get('OCP\\ICacheFacto...')
#23 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#24 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#25 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OCP\\Lock\\ILocki...')
#26 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OCP\\Lock\\ILocki...', false)
#27 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OCP\\Lock\\ILocki...')
#28 /var/www/nextcloud/lib/private/Server.php(2000): OC\AppFramework\Utility\SimpleContainer->get('OCP\\Lock\\ILocki...')
#29 /var/www/nextcloud/lib/private/Files/View.php(119): OC\Server->getLockingProvider()
#30 /var/www/nextcloud/lib/private/Server.php(430): OC\Files\View->__construct()
#31 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(155): OC\Server->OC\{closure}(Object(OC\Server))
#32 /var/www/nextcloud/3rdparty/pimple/pimple/src/Pimple/Container.php(118): OC\AppFramework\Utility\SimpleContainer->OC\AppFramework\Utility\{closure}(Object(Pimple\Container))
#33 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(122): Pimple\Container->offsetGet('OC\\Files\\Node\\H...')
#34 /var/www/nextcloud/lib/private/ServerContainer.php(137): OC\AppFramework\Utility\SimpleContainer->query('OC\\Files\\Node\\H...', false)
#35 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(56): OC\ServerContainer->query('OC\\Files\\Node\\H...')
#36 /var/www/nextcloud/lib/private/Server.php(1363): OC\AppFramework\Utility\SimpleContainer->get('OC\\Files\\Node\\H...')
#37 /var/www/nextcloud/lib/base.php(588): OC\Server->boot()
#38 /var/www/nextcloud/lib/base.php(1076): OC::init()
#39 /var/www/nextcloud/console.php(49): require_once('/var/www/nextcl...')
#40 /var/www/nextcloud/occ(11): require_once('/var/www/nextcl...')
#41 {main}root@DietPi:/#
Regards
przemko
Post by przemko »
Can I upgrade Mariadb on Dietpi?
basically you could do the upgrade with the system as is. Once done, uninstall NextCloud. This should create a database backup. Afterwards try to perform a new install of NextCloud. The database backup should be loaded automatically.
przemko
Post by przemko »
Can You tell me why on my Dietpi that first command don't work:
 sudo sed -i 's/buster/bullseye/g' /etc/apt/sources.list{,.d/*.list}
sed: nie można odczytać /etc/apt/sources.list.d/*.list: Nie ma takiego pliku ani katalogu
It says there's no file or folder.
Regards.
can you have a look to the folder
ls -la /etc/apt/sources.list.d/
przemko
Post by przemko »
dietpi@DietPi:~$ ls -la /etc/apt/sources.list.d/
razem 8
drwxr-xr-x 2 root root 4096 cze 21 13:31 .
drwxr-xr-x 7 root root 4096 paź  9 23:12 ..
you could have a look to your backup if thee was a source list existing or not. If not you should be fine.
przemko
Post by przemko »
Hi, I make upgrade to bullseye onece again. Can You tell me do I need that commands at the end after full-upgrade?
/boot/dietpi/func/dietpi-obtain_hw_model
. /boot/dietpi/func/dietpi-globals
I'm afraid to not broke my GRUB again.
I reboot and system is up.
Now I uninstall Nextcloud and install again but still the same errors.
I remove everything (nextcloud_data filder and mysql folder) but when I see services status I mariadb is failed. Can I purge maraidb and lighttpd?
Will my Emby works after that?
Regards.
Of caus MariaDB is failing if you removed mysql folder as it contains the database files.
Yes you could remove everything if you like using dietpi-software
The following is loading the new environment for DietPi script. It will not install anything. Same is done on a reboot.
Emby has an own web server and us not using Lighttpd.
