Lighttpd SSL failures after upgrade from Buster to Bullseye Topic is solved
Re: Lighttpd SSL failures after upgrade from Buster to Bullseye
did you had any Anti Virus stuff configured ??
"The antivirus executable could not be found at /usr/bin/clamscan"
przemko
Post by przemko »
I think I uninstall that clamscan app from nextcloud dashboard because I see some errors even when nextcloud was working.
przemko
Post by przemko »
I see also that errors in log:
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Deprecated event type for \\OC\\Repair::info: Symfony\\Component\\EventDispatcher\\GenericEvent is used","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::info: Repair info: JS cache cleared","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"no app in context","method":"","url":"--","message":"Deprecated event type for \\OC\\Repair::step: Symfony\\Component\\EventDispatcher\\GenericEvent is used","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Clear every generated avatar on major updates","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Add preview background cleanup job","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Queue a one-time job to cleanup old backups of the updater","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Cleanup invalid photocache files for carddav","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Add background job to cleanup login flow v2 tokens","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Remove potentially over exposing share links","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::info: Repair info: No need to remove link shares.","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Clear access cache of projects","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Reset generated avatar flag","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Keep legacy encryption enabled","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Check encryption key format","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Remove old dashboard app config data","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Add job to cleanup the bruteforce entries","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Queue a one-time job to check for user uploaded certificates","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Repair DAV shares","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Repair::step: Repair step: Add background job to set the lookup server share state for users","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:00+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::startCheckCodeIntegrity: Starting code integrity check...","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:06+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::finishedCheckCodeIntegrity: Finished code integrity check","userAgent":"--","version":"21.0.4.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:06+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::updateEnd: Update successful","userAgent":"--","version":"21.0.5.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:06+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::maintenanceDisabled: Turned off maintenance mode","userAgent":"--","version":"21.0.5.1"}
{"reqId":"P3C7iKMIicZQftPdZNfa","level":1,"time":"2021-10-01T15:31:06+00:00","remoteAddr":"","user":"--","app":"updater","method":"","url":"--","message":"\\OC\\Updater::resetLogLevel: Reset log level to Warning(2)","userAgent":"--","version":"21.0.5.1"}
{"reqId":"pH0RXu5g8B0jj65usIgz","level":2,"time":"2021-10-04T14:00:34+00:00","remoteAddr":"","user":"--","app":"appstoreFetcher","method":"","url":"--","message":"Could not connect to appstore: cURL error 7: Failed to connect to apps.nextcloud.com port 443: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://apps.nextcloud.com/api/v1/apps.json","userAgent":"--","version":"21.0.5.1"}
BTW these messages are from "2021-10-01T15:31:06+00:00" > 1st of October
Ah and Anti Virus messages from "2021-01-15T19:10:06+00:00" > Jan 2021. They are pretty old.
you need to check messages from last reboot.
przemko
Post by przemko »
They are on the beginning of file nextcloud.log?
not sure. you could try to copy file to a desktop computer do be able to have a better view.
przemko
Post by przemko »
I try ncc log:tail and see something different:
root@DietPi:/# ncc log:tail
  Level     App                 Message        Time
  Info      no app in context   Deprecated event type for \OC\Repair::step: Symfony\Component\EventDispatcher\GenericEvent is used        2021-10-01T15:31:00+00:00
  Info      updater             \OC\Repair::step: Repair step: Repair DAV shares        2021-10-01T15:31:00+00:00
  Info      updater             \OC\Repair::step: Repair step: Add background job to set the lookup server share state for users        2021-10-01T15:31:00+00:00
  Info      updater             \OC\Updater::startCheckCodeIntegrity: Starting code integrity check...        2021-10-01T15:31:00+00:00
  Info      updater             \OC\Updater::finishedCheckCodeIntegrity: Finished code integrity check        2021-10-01T15:31:06+00:00
  Info      updater             \OC\Updater::updateEnd: Update successful        2021-10-01T15:31:06+00:00
  Info      updater             \OC\Updater::maintenanceDisabled: Turned off maintenance mode        2021-10-01T15:31:06+00:00
  Info      updater             \OC\Updater::resetLogLevel: Reset log level to Warning(2)        2021-10-01T15:31:06+00:00
  Warning   appstoreFetcher     Could not connect to appstore: cURL error 7: Failed to connect to apps.nextcloud.com port 443: Connection timed out (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for   2021-10-04T14:00:34+00:00
I search in google and find topic about app store error.
https://help.nextcloud.com/t/no-app-sto ... c-18/69644
Meybe that is something familiar.
this is a warning message and according the log 4 days old 2021-10-04T14:00:34+00:00
przemko
Post by przemko »
Hi, @Joulinar I cannot find any fresh log entry in nextcloud.log file. Today I need nextcloud to my work and I restore dietpi-backup. Everything was OK and after reboot system don't want to start. It stuck on grub error.
Grub loading.
Welcome to GRUB!
error: symbol 'grub_file_filters_all" not found.
grub rescue> _
Can You help with that?
Regards.
Hmm this is a broken bootloader you have. Not sure how to work around this. Maybe @MichaIng will have an idea.
