Some reinstalls of software after upgrade from Buster to Bullseye fail Topic is solved
fhals
Re: Some reinstalls of software after upgrade from Buster to Bullseye fail
Post by fhals »
All my installations are up and running, upgrade to Bullseye is successfully finished. Thank you all for your time and knowledge!
