Some reinstalls of software after upgrade from Buster to Bullseye fail Topic is solved
Re: Some reinstalls of software after upgrade from Buster to Bullseye fail
ok maybe a new setting that error.log is disabled by default :?
nigelf
Post by nigelf »
could this be the issue?
https://archlinuxarm.org/forum/viewtopi ... 65&t=14690
though it comes back to the same as the previous link & 'setenv mesontimer "0"' followed by a reboot didn't seem to help
did you guys tried the solution from the Odroid forum post?
nigelf
Post by nigelf »
yes - edited /boot/boot.ini to switch off mesontimer (setenv mesontimer "0") & rebooted - :-(
maybe it'll work for fhals...
fhals
Post by fhals »
@nigelf , Heureka, you found it!
Edited my boot.ini and set
According to boot.ini this setting should disturb a smooth video playback.
After rebooting, Mariadb is back to work on my Odroid.
(Lighttpd quit working now, hopefully, this is another story)
Well done, thanks!
nigelf
Post by nigelf »
:-) great news - I shall have another go later. Fingers crossed!
@fhals
maybe open a new post if there are further issues on other apps. Just to avoid to many issue in a single post.
fhals
Post by fhals »
Yes, I will if I can't get it back to work on myself.
Seems to be plugin-related, not mesontimer.
Thanks.
btw indeed MariaDB has errorg.log disabled by default now. I did a test installation on Buster and error.log is enabled :)
Good to know that behavior changed using Bullseye 8)
nigelf
Post by nigelf »
...& I can confirm that the mesontimer solution worked here too - i had simply forgotten to relink the databases
